As a company driver I drop and hook a lot of trailers and although the trailers are less than three years old before they are sold, some of them are a little misaligned. Do you know all of the reasons what could cause this? I imagine one reason is if bad drivers keep ramming the kingpin. Could it also be dragging the wheels on a shoulder where the tires are in the grass? Or is it just a bent kingpin? One trailer was so bad that I tried to get it fixed but every place I took it to said they cant fix it while loaded. I wonder why that is or how it is fixed? Thanks.
Anyone know what causes trailers to dog tail?
Discussion in 'Experienced Truckers' Advice' started by TruckRunner, Apr 15, 2018.
Page 1 of 3
Usually it's because the tandems are misaligned due to someone jackknifing while backing with a heavy load
Rollr4872 and TruckRunner Thank this. -
Sharp u turns can cause alignment issues especially guys that do this in tight lots like trk/stps at a high rate of speed.
Curbing tires also.
Heck we've had brand new trlrs come from the factory and weren't aligned correctly from the start.
If your fifth wheel isn't greased good enough it will sometimes simulate a misalignment.
A dry fifth wheel will also cause you to saw your steering wheel.Grubby, Studebaker Hawk, Hammer166 and 2 others Thank this. -
Too much weight at the back of the trailer can cause a pendulum effect.
Grubby Thanks this. -
If its a significant Off-track, trailer was probably in some sort of crash and the tandems are no longer aligned with trailer frame. Or possibly something has broken in the axle-suspension-frame assembly and an axle has shifted back or forward on one side.
Grubby, TruckRunner and Rollr4872 Thank this. -
A dry 5th wheel can usually be "felt" with subtle "shifts and pops" on smooth roads as the "friction hold" at the 5th wheel gives way.
Grubby, TruckRunner, Lav-25 and 1 other person Thank this. -
Are you puling a single trailer or doubles?
Axles are out of alignment for whatever reaaon.
You see 4 wheelers doing the same thing once in a blue moon. More common on older rear wheel drives and pickups. -
Most storage trailer I've pulled did that, and those trailer looked like they were abused.
Look in the mirror and you could see one side of the trailer, and the other mirror could only see the front corner. lolTruckRunner Thanks this.
Page 1 of 3
