ANYONE KNOW IF YOUR TRUCK HAS TO HAVE REVERSE LIGHTS?
Discussion in 'Ask An Owner Operator' started by yzman720, Mar 28, 2019.
  1. yzman720
    yzman720 Light Load Member
    57
    11
    Sep 19, 2018
    On my truck it just has 2 taillights with no reverse light. Does anyone know if the tractor is required to have a reverse light?
  3. Ridgeline
    22,599
    119,963
    Yes, got a violation for not having one.
    Fmcsa 393.11
    yzman720, PE_T and Slowpoke KW Thank this.
  4. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,826
    Dec 7, 2015
    OK
    What he said
    rank and yzman720 Thank this.
  5. PE_T
    PE_T Road Train Member
    I think the exception would be a very, very old truck that didn’t come with a reverse light from factory.
    Grumppy, yzman720 and x1Heavy Thank this.
  6. Ffx95
    Ffx95 Road Train Member
    1,369
    2,632
    May 18, 2017
    What’s the year and model of your truck?
  7. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,141
    Mar 5, 2016
    White County, Arkansas
    And bobtail.
    DOT still requires a reverse light on the tractor anyway. Your shop can weld one and run wires to a switch to operate it.
    PE_T Thanks this.
  8. Gumper
    Gumper Road Train Member
    1,579
    3,845
    Jan 7, 2018
    Butte, MT
    Mine doesn’t have lights that come on while in reverse. I do have two lights mounted on the frame that I can manually turn on with a switch if I so choose. No one has ever given me any trouble for it.
  9. Ridgeline
    22,599
    119,963
    Yeah there is, 1968. Anything after that, has to have one.
  10. rollin coal
    rollin coal Road Train Member
    13,436
    27,386
    Mar 29, 2008
    TN
    Mine has never had a backup light but it does have two spotlights on the back of the cab. Those count for backup lights. If the officer asks you to put it in reverse turn those lights on and you have "backup lights". If you have work lights on the back of your cab as long as the lenses are clear you have backup lights.
  11. Ridgeline
    22,599
    119,963
    You are right, the spots can be considered back up lights, the regs doesn't specify where the lights are to be placed.
    BoxCarKidd, x1Heavy and rollin coal Thank this.
