Anyone know how to get road grade from google maps or some other source?
Discussion in 'Questions From New Drivers' started by Labrador, Oct 26, 2022.
  1. Labrador
    Labrador Medium Load Member
    485
    536
    May 31, 2018
    Is there an online map, like google maps, where you can click on a location (on a road) and see what the percent grade is at that location? I drove today on Park Ave, Laguna Beach with 30,000 lbs of sand and it was a hair raising experience to say the least. I would guess it took 15 minutes to climb to Top of the World, the truck was full throttle the entire way going about 5 mph,maybe 4 mph. I am really glad the truck made it.
    Boondock Thanks this.
  3. Blu_Ogre
    Blu_Ogre Road Train Member
    8,350
    49,590
    Jul 14, 2013
    Out west
    I think Google Earth did a while back. Haven't looked at it in years.
    Boondock and Labrador Thank this.
  4. REO6205
    REO6205 Road Train Member
    13,168
    60,490
    Feb 15, 2014
    California.
    Everything on top of that hill probably got there on a truck. If they can do it, you can do it.
  5. Blu_Ogre
    8,350
    49,590
    Jul 14, 2013
    Out west
    Pulled up a topographical map and found the high school is at about 150 foot, the junior High is at about 750.
    You climbed about 600 feet in a little over a mile (5280 feet) so an average of about 10% grade.
  6. Labrador
    485
    536
    May 31, 2018
    I think this was even more than 10% grade...maybe 15%...more in some places
  7. Boondock
    Boondock Road Train Member
    1,198
    10,072
    Jul 20, 2019
    There's a couple atlases you can get called mountain directory west and mountain directory east.
    krupa530 and Labrador Thank this.
  8. tscottme
    tscottme Road Train Member
    I asked about this a few years before I went out West. Mountain Passes Steep Grades - RV Must Haves!
    IMO, you only need to read the signs. EVERY steep descent has signs posted well before you begin going downhill. Many of them will even post a reasonable speed for trucks, and some of them have different speeds based on your gross weight. I decided not to spend money for another book of maps because you will seldom have enough time to do the calculations to see if the extra time spent avoiding a steep climb/descent can be made up in other ways. Climbs and descents are a part of trucking and you should learn to go up/down hills safely. As a rule, you should not pass any truck your first time on whatever hill you find yourself unless you are empty and the other truck is heavy. I used this rule in bad weather out West, also. "You can go down a hill too slow many times, but only go down it too fast once."
    Labrador and Munch75 Thank this.
  9. Labrador
    485
    536
    May 31, 2018
    Here is what a part of the road looks like
    Google Maps
    D.Tibbitt Thanks this.
  10. D.Tibbitt
    152,842
    Residential delivery? That road looks like fun
    Cattleman84 Thanks this.
  11. Labrador
    485
    536
    May 31, 2018
    The city or county was doing some work on a road and needed sand delivered.
    Cattleman84 and D.Tibbitt Thank this.
