Anyone know how to force a Rand TND 730 to update it's GPS position?
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Farmerbob1, Dec 18, 2017.
  1. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,791
    Jan 17, 2017
    Every time I go on hometime, I turn off and disconnect my GPS, put it in my bag, and take it home.
    When I return from home time after 4 days or so, install it in the truck, and turn it on, it takes between 30 minutes and 6 hours to restore GPS position.
    Rebooting the device does not work.
    Resetting the device does not work.
    Is there some sort of secret squirrel function to force the machine to look at satellite position data, rather than #### around and be useless for hours?
    IluvCATS Thanks this.
  3. LoreeTrucking
    LoreeTrucking Bobtail Member
    7
    Dec 25, 2017
    Wakefield, KS
    I have a TND 740. It's locked up on the black screen of death. Any ideas on how to reset or reboot it? RMD customer service so far has been worthless. I can't ever get ahold of anyone, or get them to reply or respond to my calls, messages, emails, etc.
  4. Farmerbob1
    3,685
    5,791
    Jan 17, 2017
    The 730 has a tiny little button on the back just the right size to press with a ball-point pen tip. I have to use it frequently.
  5. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    All you need is a big hammer, or set it under the drive tires for an hour. That is the best solution I know of.
    Makeajump Thanks this.
  6. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    Call Customer Support and let them know the GPS receiver is bad.
    This should have went to the support thread
    Rand McNally Support Thread. (Part 3)
  7. Farmerbob1
    3,685
    5,791
    Jan 17, 2017
    Once again, I have returned from home time and my Rand McNally TND 730 absolutely refuses to detect GPS satellites. As normal, I repowered the device before leaving the truck, and left it repowered in my electronics bag until I returned to the truck several days later.
    I have taken it 10 feet away from the truck on its power cable. I have disconnected it from its power cable and walked it into the middle of a nearly empty parking lot. I have repowered and repowered the unit, several times.
    There are no clouds. I can see stars. There are no buildings over 1 story tall anywhere near me.
    There is absolutely zero possible reason for the device to be so obstinately, stupidly stubborn about not picking up GPS signal.
    Anyone know of any way to reliably force the Rand to look for signal, because I suspect that it isn't even bothering to look, since the conditions are so perfect.
  8. Mark Kling
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    Did you look at post 5? since yours is post 6.
    LGarrison Thanks this.
  9. IluvCATS
    IluvCATS Road Train Member
    4,091
    8,976
    Dec 1, 2014
    Seattle, WA
    This happened to me. I called the company. Takes forever waiting on hold. They told me to keep resetting it with a pin on the tiny button in back. Eventually it reset (found the satellites) while I was driving.
  10. IluvCATS
    4,091
    8,976
    Dec 1, 2014
    Seattle, WA
    I’m sick of Rand not knowing where a address is. I might try garmin.
  11. Farmerbob1
    3,685
    5,791
    Jan 17, 2017
    No, because post 5 was not a response to me.
    Also, the GPS receiver works just fine, as long as I do not repower the unit and take it home.
    The ONLY time.it has issues with getting GPS data is after home time.
