Anyone have Sears Atlas 80 Elite seats?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hanadarko, Aug 17, 2010.
  1. Hanadarko
    Hanadarko Independent Owner/Operator
    2,962
    927
    Oct 1, 2009
    Midwest
    I got a new pair of Elite 80 seats in the rig a few weeks ago. I was wondering if anyone had these and if so, does the seat tend to go lower to the floor when the rig is sitting in a lot for a few days (as the primary air tank looses pressure) ?
    After about 3 days, my driver's seat is basically on the floor (passenger seat seems OK) and at this time, my primary tank has about 30psi in it and the secondary tank has about 80psi.
    I guess I had thought that the seat might retain air no matter what the system itself does....?
    :biggrin_25521:
  3. droy
    droy Heavy Load Member
    828
    159
    Jun 11, 2008
    Iowa, LA
    Can you say "loosing air pressure"?:biggrin_25522:
    After reading a bit of your other air leak thread, I know that is not what you want to hear. Replaced my factory seat with a "top of the line model" from Seats Inc about three years ago, this seat was in another truck, that I traded on my present truck, after putting in the original seat. Darn thing leaked down in both trucks, but apparently has a check valve in system, both my trucks would retain 100# + throughout weekend off, but seat would leak down! Not enough to drop to floor, but enough to hit the floor whenever I dropped my fat butt in it. Talk about a rude awakening! Usually wound up with hot coffee in lap, and badly jarred back. Never could find the leak, just learned to sneak into seat.
    Try the soap and water at the adjusting buttons would be my suggestion.
    Good Luck
    Hanadarko and true blue Thank this.
  4. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    That's awesome. Thanks for the laugh!!
    I called Sears Seats. She told me to soap up the fittings/switches (here we ####ing go again) and if I find something, they will send it to me no charge - or I can take it back to KW for fix under warranty. Yea...I want to go back to KW and GRAB MY ANKLES AGAIN...
    :biggrin_25521:
  5. TURKER
    TURKER Medium Load Member
    344
    97
    Aug 11, 2009
    Raleigh NC
    I just installed one of the sears 80 in my truck I also had air leak. Every 10 minutes had to inflate the seat to keep it high.I called the seller they told me the check the valves for leak. when I opened the side cover I find that hoses was not allthe way in .Now is all good.they offer me new valves if I need it. Price of $ 800.00 you will think they will check this for quality
  6. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    The Elite 80 seats (Ultraleather..fake) were on sale at KW for $699 in July.
    So I got a set. I will double check what you found. I havent had that issue since that one day..and I have no idea why it happened ?!
    But I agree. For this much, they should inspect that stuff. Not much we can do eh?
    :biggrin_2556:
  7. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    i like mine but i ride with no air in the seat.can't comment on air leaks. johnny
  8. RW.
    RW. Heavy Load Member
    715
    995
    Jan 18, 2009
    west central IL
    $699 isn't a bad price, I think I paid 750 for mine about 5 years ago. I don't ride with much air in the seat, but I know if you inflate the lumbar support in the back, it doesn't stay inflated very long. Not something I ever bothered to troubleshoot, other than that, I love the seat, its comfortable and holding up very well for as many times a day as I get in and out.
    Hanadarko Thanks this.
  9. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    I noticed they sort of installed the air line wrong. It is not going through the hole in the frame of the seat, but under the flange. Odd. I am going to fix that today and then put some plastic conduit over the hose so it cant rub at all.
  10. true blue
    true blue Medium Load Member
    304
    231
    Jul 13, 2011
    Harrisburg, NC
    RW, how do you like them now, after several years of use (I guess)?
    Has anyone heard anything updated on these seats? I'm planning on buying a pair for my T600, but this makes me think I need to look at National Seating or something else.
  11. bull hauler
    bull hauler Medium Load Member
    300
    80
    Apr 23, 2012
    Comfy yes, quality no, chinese crap air switches yes. I had to yank out airlines of switch panel and put needle valves and air up from air gun in cab.
    Would not buy another, how hard it is to build quality non air leak switches, i guess for them its impossible
