Anyone change a headlight on a 579?
Discussion in 'Experienced Truckers' Advice' started by snowwy, Sep 12, 2023.
  1. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    There's a cover that has to be removed to get to the headlight.
    There's a knob I think it unscrews to remove the cover. But neither side will turn. I've even tried needle nose vise grips.
    Is there a trick to getting the cover off. I don't want to break something. Youtube videos show how to replace the light but the cover is already off so no help there.
  3. Suspect Zero
    Suspect Zero Road Train Member
    2,497
    9,425
    Oct 10, 2016
    Burbank, IL
    I drive a 2020, maybe it has changed for a different year. I am not with the truck today so I can't tell you if it's the top or bottom for sure but I seem to remember it being the top where there is a thumb knob or screw in the center that you undo and the the bottom holds itself in with tabs.
    Unscrew the knob and remove it so you can grab the top and pull it up to remove it.
    ShortBusKid Thanks this.
  4. Suspect Zero
    2,497
    9,425
    Oct 10, 2016
    Burbank, IL
    Maybe this is the same (close to) set up.
  5. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Spray the thumbscrew with lubricant if you can .. as a Canadian ours rust in place if you don’t . Ps I’d often put the threads in excess grease from fifth wheel before reinstalling.
    classic_150 and ducnut Thank this.
  6. snowwy
    20,527
    13,262
    Jul 6, 2009
    It's on the bottom. And I keep spraying wd. Hoping it works its way in.
    Same setup as that video.
    Guess it's froze in there.
    Magoo1968 Thanks this.
  7. prostartom
    prostartom Light Load Member
    216
    465
    Jun 20, 2014
    Every time we pull those covers we lather up the thumb screws with anti-seize which definitely helps but sometimes they still get stuck and you end up stripping the plastic part off of the screw. Then it's time for the locking pliers, bad design if you ask me.
    Magoo1968 and ducnut Thank this.
  8. ducnut
    ducnut Road Train Member
    2,429
    7,214
    Dec 31, 2010
    SPI
    Those thumb screws are a regular maintenance item. I regularly dip mine in engine oil.
    Goodysnap Thanks this.
  9. Long FLD
    Long FLD Road Train Member
    11,366
    45,787
    Mar 4, 2015
    On my old truck I had to use channel locks to turn that thumb screw. They catch a lot of grit and don’t turn easily if you haven’t opened it for a while.
    ducnut, Magoo1968 and Goodysnap Thank this.
