Want to replace the steel rims with aluminum rims on my 2018 Wabash. There's less than half an inch of stud left with the steel rims so I'm pretty sure I'll have to put in longer studs for the thicker aluminum rims.
I've asked around a bit at shops about doing this since I figured it meant replacing the whole hub but was told it was pretty easy to just remove the existing studs from the hub and install longer studs.
Anybody know exactly how? Do I just remove the wheels and brake drum and hit the studs with a big hammer to push them out the back of the hub than repeat to put in the new studs? Looks like the brake shoes will be in the way though.
Anybody replace trailer wheel studs?
Discussion in 'Ask An Owner Operator' started by zaroba, Aug 12, 2021.
Yes. Take the brakes off. Driving the old ones out takes seconds, driving the new ones in can be tough.
zaroba Thanks this. -
Easy, take the wheels and drums off. Don't need to take the shoes off depending on the the hub style. There is usually a spot you can wiggle them out when rotating the hub, or you can pry the shoe down a bit each time to get the stud out. Hit the studs out with a sledgehammer, use an old nut on there if you don't want to damage them when hitting them. Then put the new stud in, line it up if it needs to be a certain way, oil the threads on it and use a 3/4 impact on an old nut with washers behind it to pull it in, just until it bottoms out. Use a feeler blade to confirm its tight around, don't overdo it so you stretch the stud. Use brake clean to take the oil off the threads before putting everything back together and torqueing the nuts on.
bzinger, feldsforever, ProfessionalNoticer and 4 others Thank this. -
If you’re doing studs yourself check torque after a hour or two . Then maybe a few days later. This is just in case a stud wasn’t bottomed out properly.
feldsforever, Team818 and zaroba Thank this. -
Put the new studs over dry ice for a beer or two, they shrink just enough to pop right in
feldsforever, rollin coal, Accidental Trucker and 8 others Thank this. -
zaroba Thanks this.
put studs in the freezer.
Thanks for all the replys.
Going to be home next week so the first thing I'll try is taking 2 of my drives and putting them on the trailer to see if I'll actually have to replace the studs. -
You might be able to get away with aluminum outers/steel inside, but I would think most newer stuff is set up for all aluminum
