I'm getting a fault code SPN 929 on my freightliner Cascadia. I looked it up and it says "Tire Location"
I found this bracket loose near the tire... does anyone know what this is exactly? Tire pressure sensor maybe?
thank you
Anybody know what this might be?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by speedstickman, Jun 16, 2023.
Probably speed sensor harness.
Tb0n3 Thanks this. -
Any idea if it needs to be reattached urgently? Or is it ok if I just secure it with some zipties ?
AModelCat, Oxbow and OLDSKOOLERnWV Thank this. -
That's super useful info, appreciate it!
You can see where the speed sensor mounting bracket broke off of at the brake chamber mounting nut. Inspect the opposing side to see if it is mounted in the same manner.
Yes you can remove the bracket from the ABS sensor and zip tie for temp, maybe to the top of the brake chamber clamp? -
$200,000 truck. Shaking my head.
