Anybody here got a 350 Cummins?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Isxrookie, Jun 16, 2020.
  1. Isxrookie
    Isxrookie Light Load Member
    82
    45
    Jan 24, 2011
    New Orleans, la
    What much weight are you pulling?
    What kind of transmission and rears?
    Pro and cons?
    Reliability?
    Looking to buy a truck with a 350 Cummins, 2:93 rears and a 8 Speed.
    What’s your thoughts?
    thanks in advance guys
    SmallPackage Thanks this.
  3. singlescrewshaker
    4,689
    40,504
    Dec 31, 2017
    Little Havana, FL
    Which 350 Cummins.?
    Ism
    IsL
    Isc
    Isb
    Big Cam
    Guessing that be a 1 to 1 trans with rears that tall..
    I run a 320/350hp Detroit, fuller 9speed, 4.10 rear @ >55k lbs gross & it gets the job done..
    Is a wee sluggish getting up to speed, but actually pulls hills decent..
    jamespmack and Swine hauler Thank this.
  4. Isxrookie
    82
    45
    Jan 24, 2011
    New Orleans, la
    I believe it to be a big cam. Just wanna make sure like you said that it can get the job done
  5. singlescrewshaker
    4,689
    40,504
    Dec 31, 2017
    Little Havana, FL
    If I'm not mistaken @truckdad had a 350 small cam hauling massive OSOW machines in a '72 Pete. 5×4 20 speed trans, & 4.33's rears.
    The biggest thing I'm no fan of are the 2.93 rears you mentioned.
    In a sub 80k lb application I see no reason a 350hp won't get the job done though. Will be slower than the 425-500hp of today's trucks. You can also tweak the injection pump for some more ponies, but that is above my pay grade..
    Again, I'm a sub 55k lb outfit. My 320/350hp is really only a 320hp right now because my cruise control does not work. But I do fine at that power. 30 more hp, & thinking the Big cam is more torque also should make it happen. The trucks of yesteryear got it done too!! :)
    jamespmack and SmallPackage Thank this.
  6. SmallPackage
    5,273
    16,442
    Dec 20, 2019
    Marion Texas
    The big cam 350 was putting out about 1100 ft lbs of torque. The biggest problems you are gonna have is the rear gears and trans. 3.90’s or 4:11’s and 13 speeds make an old nh Cummins pull good. You need the 300 rpm splits to keep your rpm up. The power feel is different and You will be running 2100 on the tach to what the new generation engines are doing 800 rpm less. It gets the job done but slightly slower.
    Just like an 8 second race car and a 10 sec. race car. They both get down the 1320 but in a different performance bracket.
  7. Isxrookie
    82
    45
    Jan 24, 2011
    New Orleans, la
    I think I may go and get the fuel pump amped a bit. And go from there. I have 2 trucks wity some better Rears that I can switch it 2 down the line. Then maybe the injectors.
    singlescrewshaker Thanks this.
  8. Isxrookie
    82
    45
    Jan 24, 2011
    New Orleans, la
    You think I will be ok if put switch up the tranny and rear. I have 2 trucks I can switch it out with.
  9. SmallPackage
    5,273
    16,442
    Dec 20, 2019
    Marion Texas
    Yes sir. Should not be a problem.
    Dino soar Thanks this.
  10. Cummins_444
    Cummins_444 Medium Load Member
    605
    1,014
    Apr 28, 2008
    Northwest, IN
    Man all you big steppers in here. All I got is a 300 formula. We pull steel at gross. Just takes a minute to whined her up.
  11. Rideandrepair
    17,202
    55,794
    Aug 8, 2015
    Where you at @Dino soar? They’re talking your language.
    Brettj3876 and Dino soar Thank this.
