Any way to fix a 1/8" airline quick connect?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by NightHawk365, Apr 26, 2019.
  1. NightHawk365
    NightHawk365 Light Load Member
    88
    214
    Apr 17, 2019
    North Idaho
    20190426_133424.jpg This little bugger is leaking bad, Ive cut the hose off a couple of times and reinserted, but no dice. I have read on the larger ones that you can pull the fitting and replace the o-ring, but for the life of me I can't get this one out.... Any ideas short of replacing the whole manifold?
    Old Man and Rideandrepair Thank this.
  3. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    I considered cutting or drilling out where the fitting goes, and reinstalling a bulkhead style fitting. Something kind of like https://www.amazon.com/Bulkhead-Connect-Fitting-Stainless-Threaded/dp/B07NPGN2KX
    I ended up buying the pass through and replacing the whole thing, so I'm not sure if it would have actually worked. On the Volvo one you can see the path it takes if it splits off to something like a sensor.
    If you go this route, make sure you have the correct size tubing so you don't end up getting 1/8" fittings and finding out it's 1/4" line.
    Rideandrepair and NightHawk365 Thank this.
  4. NightHawk365
    88
    214
    Apr 17, 2019
    North Idaho
    I wound up getting a new manifold, only to find out Freightliner has gone to a single unit for all models, so if you have a 22 port manifold like me, you still have to put in a "T" and Jerry rig it..... thanks for the idea though. i definitely try th9on the next go round
    Rideandrepair and loudtom Thank this.
