We are considering purchasing this truck in title above and would like to know if there are any serious known issues with it?
Also looking to sell a 2009 Pete 387 with a hole in the lower block. any takers or know what the value might be?
Any thoughts on purchasing this truck? 2015 VOLVO VNM64 T780
Discussion in 'Volvo Forum' started by LNB, Mar 9, 2017.
Injector and injector cups were a problem on most Volvo Mack engines, it's why the new 18's are now common rail. Your description is lacking information, if you'd like advice or better information actually post the specifics of the truck.
LNB Thanks this. -
The last and only Volvo I've driven was a 2012 VNL630. Put about 340k on it before the company gave me a new truck. One issue I had that you won't is a 630 bunk is too small. Another issue I had is that the "Volvo enhanced cruise control" never seemed to work anywhere close to correctly. And was terribly obnoxious with its warning indicators. It pulled pretty well, and got pretty good fuel mileage. So with a bigger sleeper and no VECC, I'd happily drive another Volvo. I did have trouble once with injectors, like ReeferOhio mentioned. But I was only down a weekend, and it was under warranty, if memory serves. So it didn't seem a deal breaker in any way.
KB3MMX Thanks this. -
So u wanna buy a Volvo, hmm..I suggest be prepared to join a "I'm on a verge of bankruptcy "club. I'm already in that club.
Loulou69 Thanks this. -
You dont see too may VNM model 780's, in fact I have never seen one, almost every 780 on the road is a VNL, so the VNM will have the old style head lights. The D13 engine with under 500K should be ok if the maintenance was done, I would get the last 6 of the VIN, then call your local Volvo dealer and find out some warranty history.
