any of you haveing problems with your scangauge d????
Discussion in 'Trucks [ Eighteen Wheelers ]' started by snowwy, Jul 8, 2013.
  1. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    my truck was perfectly fine till i bought the scangauge.
    i had an issue with the truck shutting down the turbo 2 weeks ago. had it in shop and nothing was wrong.
    i had engine light. then dpf light. couldn't regen the truck till it was shut down overnight. then engine light stayed off and i was able to regen.
    yesterday i limped into walcott with no turbo.and no engine light. this morning she's all dandy but i'm sitting at kenworth waiting to hear nothing is wrong again.
    i'm starting to wonder if my problem is the scanguage causing the ecm to glitch. since i had absolutely ZERO problems before i bought the thing.
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Run with it unplugged for a while and see if your problems go away. Then after than, plug it back in. If your problems return, unplug it and get rid of it. I can't see a scan gauge directly causing as all they are really supposed to do is read the data stream. Weird things will happen if datalinks get corrupted though. Some trucks do have separate control modules to run the aftertreatment system. These modules do communicate over datalinks, though usually private, (not the same one your scan gauge connects to).
  4. snowwy
    20,527
    13,262
    Jul 6, 2009
    it's at cummins now. and naturally. ran perfectly fine getting here. we'll see what cummins says.
    so yeah. unplugging the scangauge wil be my next step.
  5. BAYOU
    BAYOU Road Train Member
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    no way my truck is doing the same thing but ive had my scan gauge for a year or so.....
