Any luck painting Alcoa wheels?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Steve from hutch, May 3, 2018.
  1. Steve from hutch
    Steve from hutch Medium Load Member
    The wheels on my truck are far from smooth and shiny, I was thinking of powder coating but, the bake temp is over Alcoa's temp limit.
    The next best thing, paint? I know paint doesn't like to stick to bare aluminium, there are companies that "claim" their paint is formulated to work without primer on wheels. Has anyone painted their aluminum wheels and had the paint last with good results?
    Steve
  3. Ridgeline
    22,116
    113,354
    They are not bare aluminum.
    Contact Alcoa, they can tell you what you can and can't do.
  4. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Paint sticks to aluminum provided the surface is properly prepped. Do it right, do it once
    Aluminum Prep
  5. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    Have the wheels sanded and re-polished again, or do it yourself.
    There's plenty of YouTube videos on refinishing and polishing aluminum wheels.
    Derailed and p608 Thank this.
  6. benjamin260_6
    benjamin260_6 Medium Load Member
    430
    480
    Aug 8, 2012
    Ontario, Canada
    To get the paint to stick to aluminum, you need to sand it just like anything else, then use an etching primer. The etching primer eats into the aluminum so it doesn't just peel of like regular primer would on aluminum. Then paint. I did my steps 2 years ago because I was sick of polishing checker plate and it hasn't peeled off yet.
    Jazz1 Thanks this.
  7. Steve from hutch
    They may have had a surface treatment or coating on them once, I can say with no doubt they are bare aluminum at this point.
    For the sand a polish crowd, they look good for a short time plus, I kinda prefer the bright silver you see on car wheels.
    I guess I will just prime them and shoot with 2k, keep the comments coming, never know when a gem will pop up.
    Steve
  8. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    I've never done it, but I'm sure someone on here has used plastidip. No idea how long it would hold up on a semi truck rim. But a bunch of people use it on car/truck rims. Granted, those wheels don't see the miles a big truck does. Just an idea (and possibly a bad one).
  9. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Prep the right way and it will look good for years.
    Friend off mine has done it for years.
    You are correct about powdercoating a Alcoa.
    NEVER do that.
    The rim loses all strenght.
  10. rollin coal
    rollin coal Road Train Member
    13,087
    25,913
    Mar 29, 2008
    TN
    After prep spray your wheels with zinc chromate primer. That's what is used to prime/etch aluminum on civilian and military aircraft before painting, or used to be anyway. After it dries, sand and prep again then spray whatever ordinary paint/color you want on them. Just looked and you can actually buy rattle cans of zinc chromate primer from Amazon. I've heard of people wiping aluminum with vinegar to etch it after sanding and prep then priming with regular primer + paint but if it was me I would do it with zinc chromate primer.
    Jazz1, Tug Toy and Steve from hutch Thank this.
  11. Steve from hutch
    I am very familiar with aircraft painting, etching used to be done with citric acid then alodine, not available anymore. In a former life I used to fly for a completion center. I have some epoxy primer, the manufacture says this is better than etching primer of the past? I may actually still have a little bit of alodine, citric acid is the same stuff used to flush aluminum heat exchangers like radiators. The alodine was like an early e-coat, it sealed the oxide layer on the aluminum and bit into both the base metal and paint, it was a light gold wash, anyone with military aircraft experience in the 80's or 90's would recall the finish.
    The initial question was spraying a base cost directly on the bare wheel, for car wheels some of the paints sold may work, for a really durable job, there is no cutting corners. The irony is, the materials alone are going to cost me at least twice the cost to powder coat the wheels! Oh well, pay once cry once or something like that.
    Steve
