any issues with non volvo seats?
Discussion in 'Volvo Forum' started by dustinbrock, May 25, 2015.
  1. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    2006 volvo 630. I want to swap out my drivers seat, parts guy at volvo said they have had issues getting the non volvo seats in so they recommend buying theirs.
    I had a columbia with a ezrider seat and to get another in I needed to buy a special bracket or the seat was too far back........ any issues like this with the volvo?
  3. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    my 2006 volvo 780 came with (national seats) when i needed to replace the drives seat i went to volvo and was told it was a 4 week wait and $1,200 for a OEM seat.... said f-- that
    went out and found a seat i liked.... and went to a dealer and just had them drill new holds in the floor
    i did have them add 2 steel plates (2" X 16") under the flood for extra support
    just find the seat you like and have any shop drill the new holes in the floor.... i do recommend the steel under the floor (bolt the seat thru the floor AND the steel) for added safety, just make sure you SIT in the new seat before they drill the new holes to make sure it is where YOU WANT it do be...
  4. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    Just pay attention on the left of the driver seat at the base there is a harness under the floor mat, we saw sometime people drilling in this area for PTO control or something else and you can imagine the rest. . .
    Recommandation check under the floor mat before drilling.
    Ben
    Ben
  5. dustinbrock
    1,308
    901
    Apr 19, 2012
    I avoid drilling random holes in my trucks at all cost. I would rather a direct fit or buy a base adapter. if neither exist then I'll just go oem.
  6. Marshall Lucky
    Marshall Lucky Bobtail Member
    20
    14
    Nov 28, 2011
    Eastern, SD
    The base adapter shouldn't run more than $20 or so. With an aftermarket seat you may run into issues where the seat will not slide rearward all way due to hitting factory accessories behind seat (fridge, drawers, etc)
    I've seen more than one with the problem. I put a leather Legacy seat and mine and wound up rearranging the floor plan to make it work correctly lol, but to me was well worth it. Probably not the best plan of action on a 2 year old truck though.
  7. Moneymike
    Moneymike Light Load Member
    118
    31
    Apr 17, 2013
    I put a volvo seat in my freightliner. Sit in place and drill new holes. It's as simple as it sounds. The shorter the screws the better. Longer ones will give less stability.
  8. benrab
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    Just as reminder if you modify your seat set-up thinks also to seat belts, they need to be safe also for annual inspection.
    Ben
  9. flood
    4,157
    4,020
    Dec 25, 2010
    thats the reason i had the steel plates under the floor.... the only way the seat can come lose is if it rips the floor out.....
    seat belts are mounted to the seat just as OEM are
