Any Help With Fault Code 3582 Spn4364.18
Discussion in 'Trucks [ Eighteen Wheelers ]' started by habfleet, Dec 18, 2016.
  1. habfleet
    habfleet Light Load Member
    163
    23
    Feb 5, 2012
    elwood nj
    I have a 2011 Pete with a PX-8 engine(ser#73301527). Had the above code. Removed doser injector extremly caked up replaced and cleaned housing . Could see where Urea was leaking from gaskets at Particulate filter and SCR. Replaced gaskets and clamps. Cleared all faults with insite, ran forced regen. Showed doser dosing after regen soot normal . I did noticed during regen temps did not go above 800'F New to insite thought should be higher also inlet and outlet temps not much diffrent between the two. Returned truck by end of day check engine light back on, same fault code and a nasty smelling exhust now. out of ideas any thoughts or advise.
    Thanks in advance
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    For that fault, the 1st thing I do is test the DEF with a refractometer. I have found very few issues with contaminated DEF, but it's so easy to check, it only makes sense to eliminate it first. Then look for external DEF leaks and exhaust leaks, which it sounds like you've done that.
    The most common issue I've found causing that fault is a plugged DEF doser. Now you want to use Insite to perform the "Aftertreatment SCR System Test". If it fails, you can do a DEF doser override check, which involves removing the doser from the decomposition tube and measuring the flow. If that fails, there's a good chance that it needs a new doser.
    habfleet Thanks this.
  4. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    Thanks for the reply. Yes i did check the def fluid it was ok and replaced the doser injector and gasket. It was plugged
  5. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    Sorry, I missed the new doser part, I though you just cleaned it. Did you run the Aftertreatment SCR System Test? That will help narrow it down some. If that fails, then you should then do the doser override check. The override test will tell you if it has the correct flow, which will eliminate the pump/delivery side of things. If the flow is correct, then you'd be looking at an outlet NOx sensor or a catalyst issue. It's rare, but I have seen outlet NOx sensors fail without setting faults.
  6. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    Yes I did do the over ride and system OK . If the nox sensor was off would that contribute to the nasty smelling exhaust ? Thanks Again
