Any harm to grease packing oil cooled wheel bearings?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JamesMc84, Nov 29, 2020.
  1. JamesMc84
    JamesMc84 Bobtail Member
    45
    Mar 20, 2017
    just came across some wheel bearings packed with grease on a drive axle. Oil mixing with the grease. Any harm to doing this?
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    When a drive axle wheel end is serviced correctly there should be no need for grease. When I see this, I automatically think someone is trying to cover up something, like a wheel seal that was messed up or rusted seal surface.
    Biggest hiccup is your relying on grease now to lube and cool the bearings, when its supposed to be oil. Oil cant flow through the bearings as designed.
    Id make it right if it were in my bay. Any less is asking for trouble. IMO
  4. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Drive axle is a red flag. Like already mentioned. As you know differential surely isn't packed with grease..lol. On these container chassis, they are grease packed, i think, as there are lots of them with no way to add or check oil level. Newer ones not so. Have a sight glass, with a allen plug in the cover to add, or drain.
    AModelCat and Goodysnap Thank this.
  5. AModelCat
    154,273
    Grease in oil lubed bearings is a big no-no. Either they're trying to cover up a leaking seal or its a simple lack of knowledge.
  6. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    I had a coworker tell me once that he packed all wheel bearings to keep them lubed until they got oil. My explanation of how it worked fell on def ears. He indicated that- " that was the way he had always done it" . He did it my way as it was my shop. I cant recall his name so he didnt last long.
    Sometimes people are taught incorrectly and other times they just make dumb decisions because they dont know any better. You hit the nail on the head. LACK of knowledge.
  7. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    Yup. I just fill up the oil well in the hub. Get everything set, put cap on. Fill to level, then spin assembly a few times. Recheck oil level. Usually have to add a bit. When i start driving, go 10 or so miles or so stop and see how everything is. Temp and leaks. Take a peek at it during the day also. Mayby i worry to much?
    Bean Jr. and Goodysnap Thank this.
  8. AModelCat
    154,273
    Drive axle you just make sure diff is full, then jack one side up a couple inches, then the other. That lets the oil from the housing run down into the hub. Then just check/top off the diff.
    stillwurkin, Dino soar and Goodysnap Thank this.
  9. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    Yup on the drive. Can't see through axle end anyway.
  10. wore out
    wore out Numbered Classic
    15,319
    184,960
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    There is a plug on most drive hubs that let's you fill the center cavity after a repair. Takes the guess work out of it
    lester Thanks this.
