Any Anti-Theft/Break In Alarm Systems for Class 8 Trucks?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by STexan, Jul 16, 2013.
  1. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I'm going to ask this here in the owner-operator forum and see what happens. Does any of the class 8 truck manufacturers offer on "on-star" type system or is there perhaps an aftermarket system? I'm more particularly interested in knowing if there are fuel theft alarms and vehicle break-in alarms specifically for trucks. The system I would like to see would utilize an on board, programmable cellular phone to dial a number with an appropriate message and/or text message in the event of a break-in or fuel theft. They would essentially operate like modern home security systems however the fuel theft alarm would probably need to be incorporated at the factory build level to keep the fuel gauge system always energized and operational, regardless of key state or engine state.
    Also, have you seen any o-o level trucks that offer lock remotes like you see on virtually all newer cars and pickups?
    Does any heavy truck manufacturer offer a "basic" alarm system like we see with typical cars and pickups? ... from the factory or aftermarket
    Thanks
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Sure they do just google it. I watched I forget the show? Trick this truck? They installed an alarm system with an invisible laser or such on the steps. It also had where you could record the alarm. They used a barking dog. It was pretty cool. They have ignition interlock ones too.
    http://www.babaco.com/products/Tractor_Alarm-8-17.html
    You can customize one at www.Viper.com like glass break, motion sensor, field disturbance sensor, programmable voice.... I think that was the one on that show. Not only the alarm it can cut power to the ECM or ignition.
  4. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    It doesn't make sense why a decent alarm system with cellular paging component isn't offered from the Paccar or others. Truck manufacturers are always the last to incorporate high-tech and/or other sensible options. A fuel theft sentry one would think would have been offered many years ago from the manufacturer when fuel went well over $3.00/gal and fuel theft became common-place. I don't put much stock in "locking fuel caps", and the idea many can't park their rig in their driveway makes cellular link technology would be assumed in any alarm system.
  5. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Kinda low tech but very effective.
    jcross Thanks this.
  6. Charli Girl
    Charli Girl Road Train Member
    1,371
    668
    Mar 23, 2013
    Houston,Tx
    I bob tailed to an alarm business years ago n put one on my truck,if you stepped on side of my truck it would sound the alarm. Just bought this truck and haven't had a chance to get one on this one yet,but I agree they should come equipped from the dealer,geez the value of the truck alone without the load is alot more than a 4wheeler! :biggrin_25510:
  7. Mr. PlumCrazy
    Mr. PlumCrazy Road Train Member
    1,341
    606
    Jul 30, 2009
    Lexington NC
    Thing with motion sensors I had a customize van with high dollar electronics had a viper alarm I could leave the windows down and if you stick your arm in it would go off. Down side wind woiuld set it off
  8. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I wouldn't want a movement sensor due to wind situations. A simple system that activates when a door is opened (light comes on) and maybe some sort of "tamper vibration" detection. (detects tampering with fuel caps or removing side panels or load locks) But that would probably false every time a heavy truck rolled 9bounced) by or somebody slammed a door adjacent.
  9. slavic258
    slavic258 Bobtail Member
    Sep 22, 2011
    toronto on
    http://www.magtec.com/
    I have their system on my 03 t600 since 04, still works, never had any problems, also don't know if anyone was trying to still my rig
  10. Ridgeline
    22,103
    113,210
    If you go with something like VIper, or another car type alarm, always have them replace the wiring with something heavier than the 20 gauge wire that comes with the kit.
  11. Charli Girl
    1,371
    668
    Mar 23, 2013
    Houston,Tx
    Y is that? :biggrin_25519:
