any advise on how to disable the "ABS Warning" light on a 2002 FLD Freightliner?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TowHaul, Jan 11, 2018.
  1. TowHaul
    TowHaul Medium Load Member
    406
    77
    Mar 7, 2016
    I have my first DOT Inspection tomorrow. I am happy at some future point to try to diagnose the problem, the ABS light Intermittently goes on and off, seems to be without reason. I have to pass this DOT Inspection and i should pass it only thing that bothers me is the ABS Warning light randomally popping up on the dash cluster display. I would like to disable it, any advise on the best way to do so temporarily? Truck is a 2002 Freightliner FLD with a C10 motor.
  3. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    I good inspector will watch when the key is turned on, that the abs lights come on and then go off. This is why I like pre 1997 trucks. Fixing that light can be expensive. Good luck.
    CrappieJunkie Thanks this.
  4. TowHaul
    406
    77
    Mar 7, 2016
    taking it to a TA on purpose... keeping fingers crossed that those are typically not home to the "good inspectors"... Either way i would like to go into this by disabling the light. Yes the repair would be a total ripoff. Also i live 1 hour away from the inspection site (this new company only allows specific locations to do the inspections) so I have once chance to get this possibly passed.
  5. Oldironfan
    5,777
    5,541
    May 22, 2017
    You can be shut down by a DOT officer if they check for this. And I mean oos until it's fixed.
  6. goforce
    goforce Light Load Member
    168
    76
    Apr 12, 2007
    South, Ga
    Not an OOS. Just a write up.
    snowman_w900 Thanks this.
  7. PandaPancake
    PandaPancake Light Load Member
    225
    272
    Dec 23, 2017
    This is not an expensive fix. Slide under there, make sure all the wires are connected. Shine your light and make sure that brass ring is clean if not clean it. Tap the sensor back into place. If you had been doing this from the beginning fixing it would take 2 minutes after you figure out which one is your problem child
  8. TowHaul
    406
    77
    Mar 7, 2016
    goforce is correct, its not a shut down offense....
  9. Oldironfan
    5,777
    5,541
    May 22, 2017
    Depends on how they feel like treating you.
  10. TowHaul
    406
    77
    Mar 7, 2016
    also as typical when asking for help on internet forums... i am not asking for what is shut down offenses, my question was clear, how do i disable it temporarily? I'll fix it myself when i have time, not a question of law or ethics, it is a simple electrical question....
  11. Oldironfan
    5,777
    5,541
    May 22, 2017
    So just remove the bulb out of the dash.
    austinmike Thanks this.
