any advantage running two antennas?
Discussion in 'CB Radio Forum' started by T-RIX, Dec 7, 2011.
  1. T-RIX
    T-RIX Light Load Member
    125
    58
    Jul 7, 2011
    Fort Lauderdale, FL
    I have a cobra 29 classic for my truck but need a new antenna set up. There are mounts on the top of both mirrors. I'm not interested in amps or talking to the moon. Any practical advantage running two? How long should I get? Thanks
  3. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    The advantage might be to kill a dead spot because of the cab. As for how long the longer the better however you have a height limit so you would have to know how high the mount is and go from there.
    T-RIX Thanks this.
  4. ds2dale
    ds2dale Bobtail Member
    31
    13
    Nov 8, 2011
    Lompoc, CA
    Using 2 antennae gives you better propagation (range) along a line that is perpindicular to the line between the 2 antennae. On an omnidirectconal signal-strength chart, the TX/RX pattern looks like a 'figure 8'. The best direction for communication will be directly in front of- and behind- your truck.
    The 2 antennae must be electrically identical. Best propagation if they are 1/4 wavelength (use the freq for chan 19/20). Just get 2 of the same antennae. Adjust both antennae length for the lowest overall SWR. Under 2 is good - over 4 is real bad. 1.1 is fantastic.
    KJ6RGV
    Sent from my DROID X2 using Tapatalk
    RAGE 18 and T-RIX Thank this.
  5. Tricky Rick
    Tricky Rick Light Load Member
    177
    91
    Oct 25, 2010
    Northwest Mississippi
    When I was driving a Columbia, my set up was a Cobra 29 Classic with the dual Radio Shack 4 ft. fiberglass antennas with the co-phase coax that came with the antennas. I pull pup vans. I used the factory mirror mounts. It was near perfect SWR and the range was very satisfactory for a legal radio. 2-4 miles average range. Now I run a 2010 Cascadia, and use the factory stock antennas/coax, and it actually works about as good. I tried a 5 1/2 ft. Francis, and a Skip shooter mounted on the rear of the cab near the center and it was a little better, but not worth the trouble.
    T-RIX Thanks this.
  6. T-RIX
    125
    58
    Jul 7, 2011
    Fort Lauderdale, FL
    thanks..... I picked up one 4' stick, a new antenna mount, and a 9' ready made cable. I'll try that for a while. If I just run the cable through the door jam instead of snakeing it through the pillar, door and mirror frame to the mount (having to remake the connector) will that have a detrimental effect. (if the cable gets a little smushed)
  7. josh.c
    josh.c Road Train Member
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    As long as you don't pinch it so bad that it breaks the shield and/or the conductor and make them short out on each other, it should be OK.
    T-RIX Thanks this.
  8. Tricky Rick
    177
    91
    Oct 25, 2010
    If you decide you need more range, try a 5 1/2 ft. Francis fiberglass. It worked better than the skipshooter and as good as a monkey made. They are pre tuned for the Cobra 29. I ran my coax through the door jam on my Columbia for 4 years with no problems.
    T-RIX Thanks this.
  9. mike5511
    mike5511 Road Train Member
    3,154
    1,544
    May 15, 2011
    NW Arkansas
    Not trying to be picky here, but you don't tune an antenna to a radio, you tune it to the vehicle it is mounted on. The radio doesn't have a thing to do with it.
    Tricky Rick and WA4GCH Thank this.
  10. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    YEP it works like this ..... you tune the antenna so that it looks like about a 50 ohm load at one end of the 50 ohm coax and and you will make your radio a happy camper ....
    Tricky Rick Thanks this.
  11. mike5511
    3,154
    1,544
    May 15, 2011
    NW Arkansas
    I want one of those MJF antenna analyzers really bad! I can't justify the expense, but have just always wished I had one........ To those who don't know, you don't need a radio to tune an antenna to a vehicle if you have one.
    10-4 on the 50 ohm, too bad that ideal is almost impossible to attain on a mobile setup. Everything is a compromise when it comes to mobiles, especially antenna length................going to bed....good night/morning!
