Just curious to see as the bottle of Howes in particular doesn't indicate how long will a unopened bottle be good for?
I dumped a bottle I've had for over a year into both tanks ( 260 gallons ) and the following day both fuel/water filter on truck and fuel filter on APU both became clogged...
Was it bad fuel or could the "old" fuel anti gel be a possible culprit?
Truck fuel filter had only 9k miles on it and APU about 350 hours...
Anti-Gel shelf life?
Discussion in 'Ask An Owner Operator' started by JonJon78, Feb 7, 2020.
Maybe you need shake it up first.
baha, stwik, Rideandrepair and 1 other person Thank this. -
Rideandrepair and 4mer trucker Thank this.
Didn't shake it eitherRideandrepair Thanks this. -
I changed oil Wednesday And had some power service anti-gel in the bluebottle that’s been in my shop for two years . I know it was a-year-old before that so let’s say it was three years old .
Now mind you I changed all filters fuel filters everything took off the next morning got about 150 miles and started losing power .
Looked down at my fuel pressure gauge and was registering 50 on it usually registers 85. Pulled over changed out my primary water separator filter , was so plugged I could hardly pour the fuel out of it . Cranked it back up fuel pressure gauge went back to 90 and truck is running fine so far so to answer your question that’s all I can explain is that fuel antigel was bad!Rideandrepair and JonJon78 Thank this. -
Rideandrepair, bzinger and JonJon78 Thank this.
Rideandrepair, bzinger, whoopNride and 1 other person Thank this.
I have a couple of bottles of Power Service from last year. Got me wondering now if they are ok to use.
This is directly from Power Service website.
JonJon78, Rideandrepair and PE_T Thank this. -
If its below zero you have to double the dose. You have to be careful with these bio blends with a high % of bio. Anti gel doesnt seem to work as well. You almost have to double the dose on them also.
JonJon78, Rideandrepair, PE_T and 2 others Thank this.
