i see that they are hiring, but i've never heard of them. i will be moving to that area in a few months and they are local (very convenient). any info would be much appreciated.
Andrus Transportation, St George, UT. any info????
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by plater1, Jan 27, 2011.
Page 1 of 3
Andrus is a western states carrier. They have/had a yard in Fontana. Volvos and KW's, older equipment, small carrier. Also check out a company called Cox, also there in St. George. (not affiliated with Cox in Ashland, Va.) Wal-Mrt has a DC in St.George also.
plater1 and Black Knight Thank this. -
I actually just called them for details and it sounds pretty good. They cover the 11 western states. Out with a trainer for a bit and then 6 months of team before they give you your own truck. On the road time is between 7-10 days. I have read some odd stories about them on this forum, but there are stories about all companies on here so who knows the validity of them
Really about the only thing I can tell you about Andrus is that I have a neighbor who has worked for them for at least the past 15 years. He seems satisfied with them, and appears to have quite a bit of home time.
Parke Cox Trucking runs all 48 and seems to keep their equipment in good condition. Appears to be newer stuff. They are both dry van and flatbed.plater1 and Black Knight Thank this. -
I Work for Andrus currently, they are all right, tend to run equiptment till it's dead, but maintain it well. Yards in fontana, St. George, Salt Lake and Dallas. Main customers are fed ex, UPS, Nestle Water, Walmart, amongst others.
They are good if you are a driver that can manage yourself. If you need to be babysat, you will not last long.
Cox is a good company, they run newer equiptment, and as long as your good to it, they are a good company.plater1 and Black Knight Thank this. -
thanks for the info, it seems very helpful. i will be out in st george in about a week and plan to check them out.
Black Knight Thanks this. -
Have been driving for Andrus for almost 7 years. If u treat them right they will b right with u. I have no complaints. They also have updated alot of their equipment.
Big Don and Black Knight Thank this. -
I noticed that they have two different help wanted ads in the local paper this morning. One for teams and one for solo. Sure might be worth checking into!
do there trucks have straight 10 speeds or do they use super 10s
Low miles, no direct deposit unless wells fargo. If they put your money on comdata card, its costs you $10 to get it out. They mail checks to your house...trucks are mostly automatic, volvos, older kw's and a couple prostars left. I have seen some older 9400 ih's running but that was first part of january. Got home every week under a load so most time off was 2 days. After first 30 days, miles went from 2500-2800 a week to 1500-1900 a week, not sure why? I left them because i had to take care of spouse.
Page 1 of 3
