I used some Anbesol extra strength. It has benzocaine in it. Would that have caused me to test positive on a whiz quiz? I talked to one company that does a hair test. That is scarey!
I threw to tube away after using it once.
Anbesol 80% Benzocaine = Failing Drug Screen?
Discussion in 'Experienced Truckers' Advice' started by Rug_Trucker, Oct 18, 2010.
Are you serious? Your fine, you would have to use massive amounts to fail a drug test. -
how big was the freakin tube? lol
Did you spread it on your poppy seed bagels?
don't worry about it... -
Well they can take it from other places. With a shirt off I look like a monkey. My hair doesn't get that long on my head. Only have 14 hairs up there
I was told if you get a novacaine shot you have to be off work for a day or 2 for it to get out of your system. -
Can benzocaine cause a false positive cocaine drug test?
No. Although they share a similar suffix, benzocaine and cocaine are very different substances, and benzocaine will not produce a false positive for cocaine. -
IIRC there is 22 different derivitives that can extract from the coca leaf. -
That picture is just WRONG on so many different levels!!!!!!!!!
