I feel kind of ashamed to ask but this is the 1st truck I've owned with an amp gauge. So my questions are:
What's good range and bad range and what's the purpose of the gauge.
If it goes to a "bad" reading/range what is most likely at fault causing it?
Thanks in advance for the info![]()
AMP Gauge
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SHC, Sep 10, 2011.
Page 1 of 3
Thirteen to fourteen amps in day time, and anywhere from there to twelve amps at night, depending on how much draw you have at night (like chicken lights), LED's greatly reduce the draw. A/C and heater blower motor will also put a load on the alternator. If your amperage falls off drastically it's probably the alternator, but always check for loose or broken wires first. I always carry an extra alternator with me with a pulley already installed, as you need a impact to change the pulley.
Can't answer the question really...Amps are the draw though, how much current, how much juice you're using. I've never driven a truck with an Amp gauge in it. -
Anything on the plus side = good
Anything on the minus side = bad
Amp gauges are not real informative.
A volt gauge will tell you how much you have left....
Must be an older truck?SHC Thanks this. -
Coolbreezin, PacManTrap and SHC Thank this.
My apoligies to all, I totally had my head up my @## I was talking volts, again I apoligize to SHC and all other readers.
It's on a 2004 Western Star -
puncher Thanks this.
If you decide to remove the amp guage, be sure to connect together and insulate the leads removed from the guage as the guage itself is a link in your main charge circuit and failure to connect the wires will cause 0 charge output from alternator.Crude Truckin' Thanks this. -
Puncher, had to smile here. My day is like that, all day, everyday...puncher Thanks this.
Page 1 of 3
