Delivering to Amigo's in Houston 6am Sunday. Any one have any experience unloading there? Trying to figure out if I'll have enough time to make it to Freeport by noon.
Thanks in advance.
Amigo's Meat Distributors in Houston
Discussion in 'Shippers & Receivers - Good or Bad' started by willisl64, Nov 15, 2014.
You should have a 4 AM if depending on your load. 2 hrs to unload and then get washed out 1 hr.
Like Passin said--you should be out by 6 or so...but remember--you are gonna have to run backwards aways to get washed..and unless someone knows a small one Im not aware of--you're gonna have to at least go back to the Beacon at 610 and McCarty and although it is a triple--typically they only have one bay open that time on a Sunday--and a small crew--so couple 3 trux in line in front of you--MAY become an issue time wise.....
If you're headed east on 10 when you empty out maybe try USA truck wash at X-785 in Channelview for a wash out..
Thanks - My driver checked in at 1:30 am and was unloaded and gone by 330am. Load was frozen and came off clean, no washout needed. Ironic twist - the dock foreman was an old friend of my driver's from 20 years ago when he lived in Houston. Small world.
having a friend on the dock always helps..
