Amber Triangle/Warn Engine* Indicators
Discussion in 'International Forum' started by Injun, Jun 8, 2011.
  1. Injun
    Injun Road Train Member
    8,501
    9,491
    May 15, 2010
    West o' the Big Crick
    Here's what happened:
    Had a steady amber triangle idiot light on the dash with the words "Warn Engine" in the readout part of the cluster. Stayed on steady for two days, so got it into the shop. The code being thrown indicated a problem with a DPF pressure sensor and the DPF was unable to fire as long as that light remained on. Anyone with a newer truck knows this just isn't a good thing.
    Both pressure sensors were replaced. Code remained active. Notes to International, questions, more notes.... Checked the circuits up at the engine end to see what up, yo? One circuit receiving information from seven different sources. Oops. Looks like a short. But, it was the end of the day and everybody was going home. Get to it in the morning.
    Next morning, code had cleared itself. Ran the h*** out of it to see whether it could be duplicated, no code. This, after the lead guy, following instruction from HQ, was preparing to overlay the wiring harness and rebuild the entire thing. That would be the sensor harness. But, since the code had cleared and not reappeared with a good hard run, thought it just might be a slow computer finally catching up.
    I was released and made a beeline for the truck wash. Truck all pretty, ready to r.....crap!! Code was back. Alright. Back to International. After I gave it a little thought (don't say it. I oiled those gears last week!) I suggested we find where the water was getting into the system. Knowing the weak link in any electric system is its connectors, I suggested we start there. Mechanics like to double-check things with computers these days, it seems. It was the same code.
    After poking around some, the leak was found. The wiring harness for the DPF sensors is put together in two pieces. The connection between the two is on the driver side, under the cab by the frame, about 3/4 of the way toward the rear of the truck. Mechanic dude opened it up and literally dumped water out of it. He hosed it down with that stuff that cleans and dries electric things and let it dry for about ten minutes. Put it back together, code gone. He siliconed the crap out of it to keep water from getting back into the connection.
    International has been made aware of the problem and will be deciding what the final permanent fix will be. At which time, I will return to the shop that worked with me to figure it out and have them do the repair. So that this shop can collect the money for fixing it.
    So. I have heard some folks saying they get a mysterious engine warning that shows up intermittently. Next time it happens, ask the shop to check that connection for water tightness. Mine had all weather protective stuff intact. Visually, it should have kept water from getting to those connections. Yet, water got in. I suspect there may end up being some sort of service advisory on this at some point. For now, you, at least, have the skinny on it.
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Connectors are always the weak link, and should always be checked. Glad they found it. Yes, we are aware too of the connector issues with the aftertreatment!
    Injun Thanks this.
  4. Injun
    8,501
    9,491
    May 15, 2010
    Follow-up:
    a new wiring harness was built for my truck. Just need to get back to the original shop to have it installed. Yeah, I know I could have it shipped, but those guys did a great job working with me and I think they deserve to get paid for their work.
    While I'm there, I'll have the DPF pulled and cleaned. They have the equipment on site. It's almost due, it seems to be firing off more often than "normal" and I ran five gallons of coolant through it when my EGR cooler took a dump. Might as well get it done while the truck is down anyway. It's either that or wait a month, take it to a shop that has to send them out and wait for three days.
    Oh....and I found another reason that light in the dash illuminates. Something I didn't know about, and apparently, most PM shops don't, either. If your light comes on when the engine is under load and then goes off when you're just cruising, have the crank case filter replaced. Or do it yourself. Wish I had known about that sooner. I found out the expensive way.
    daf105paccar Thanks this.
  5. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Those crankcase filters need to be changed about once a year and nobody does. It is all in your owners manual.
    Injun Thanks this.
  6. dave26027
    dave26027 Road Train Member
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    Thanks for the heads up- roadspray is basically penetrating fluid, it has no surface tension from the detergents and junk in it, it'll penetrate ANYTHING to its' core. (Truck manufacturers have always known this, too).
  7. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    And what have you got left for warranty or was it alreay expired?
    JasonMassey Thanks this.
  8. EZ Money
    EZ Money Road Train Member
    I know mine has never been changed and i get the idiot light all the time.
    The code is always high manifold temp.
    Not sure if its related to those filters or not but my oil fill cap blew off the other day.
    Where are the filters?
  9. Injun
    8,501
    9,491
    May 15, 2010
    The crankcase filter is located on the driver side, up high, near the front of the motor. Looking at it, it doesn't look like a filter cover and it's painted the same color as the block. Take the screws out and pull that cover off. You will find a squarish filter in there.
    EZ Money Thanks this.
  10. EZ Money
    Thanks Injun! I will find it today.
    Is it a washable filter or just replace it? It is a pain to get a PO for parts unless i take the truck to the dealer and wait all day.
  11. Injun
    8,501
    9,491
    May 15, 2010
    You cannot wash the filter. It runs about $60.
