Amber check engine light on
Discussion in 'Experienced Truckers' Advice' started by JC1971, Jul 30, 2017.
  1. JC1971
    JC1971 Road Train Member
    2,660
    9,709
    Jul 29, 2013
    L.A.
    2017 Cascadia, just had it in the shop for this. They said it just needed a software update. Not too much later it came on again. From what I understand this light is for the emissions system. Is there any damage that can be done if I don't stop and get it taken care of right away?
  3. striker
    striker Road Train Member
    6,023
    6,436
    Aug 8, 2009
    Denver, Co
    I find a piece of black electrical tape solves the problem.........at least that's how I solved mine
    Grubby, LoneCowboy, upnorthwpg and 6 others Thank this.
  4. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    My freightshaker dealer that works on ours said a amber light needs attention, but dont freak out. A red light, best shut that truck down as soon as possible... take it for what its worth, 3rd hand advice over the internet... :)
  5. VIDEODROME
    VIDEODROME Road Train Member
    1,487
    1,297
    Jun 7, 2007
    angola, in
    Mine does that when pulling heavy loads in hills going east. Then it goes out when I come back to the Midwest.
    Maybe it's a New Jersey proximity warning light.
    JC1971 and Cottonmouth85 Thank this.
  6. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,757
    Sep 20, 2014
    Generally the engine light with nothing inside means it should get checked but don't freak out. The engine with the wrench in it is more serious. If you get the red light you risk imminent damage to the engine or it's about to shut itself down.
    JC1971 and street beater Thank this.
  7. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Lots of minor issues it could be, but more than likely has something to do with the DPF system. May have a clogged DP filter that needs special attention. Regardless, there is a code that will point you in the right direction once you extract the info
    EZ Money and JC1971 Thank this.
  8. EZ Money
    EZ Money Road Train Member
    Is this a Cummins?.....I agree with STexan...probably DPF related..They have several sensors before and after the filter.
    Also the DPF needs baked and cleaned about every 250k...
    It should show any active or inactive codes if the yellow light was or is on.
  9. mustang190
    mustang190 Road Train Member
    2,846
    6,115
    Jan 18, 2011
    Florida Panhandle
    Do what striker said and then turn up the volume on the radio. Usually solves the software problems.
    striker and motocross25 Thank this.
  10. striker
    6,023
    6,436
    Aug 8, 2009
    Denver, Co
    Conversation with my boss:
    Check Engine light is on..................................................................
    Ok
    Do you want to scan it and see what the problem is?
    Maybe
    Ok
    3 weeks later
    Check engine light went off for a couple of days, it's back on now
    ok
    We've had this same conversation for slightly over a month
    EZ Money Thanks this.
  11. JC1971
    2,660
    9,709
    Jul 29, 2013
    L.A.
    It just needed a software update. If the shop at the terminal had updated it correctly the first time I wouldn't have lost a day.
