Aluminum pipe stakes OK?
Discussion in 'Flatbed Trucking Forum' started by Semi Crazy, Jul 10, 2013.
  1. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Anyone get rejected for not having steel pipe stakes at any shippers?
    I have Fontaine with aluminum bed and sides so I don't want steel stakes. I'd really prefer something that's gonna bend before it cracks my stake pockets.
    I had Great Dane pockets crack at weld with 1/4" wall steel tubing for pipe stakes when used to stop rolling pipe so don't want to go that route with present trailer.
    Anyone use sidekit posts for pipestakes?
    I am considering welding up some steel pockets to install under my existing ones. I don't want to cut out a section of rub rail like a lot of them do in TX. More like something I could bolt to the underside of a pair of cross members but then the sliding winch side will need special consideration.
  3. BAYOU
    BAYOU Road Train Member
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    I use my uprights off my side kit all the time trust me they don't last........I've only had one place tell me now way they needed to be steel that was womble pipe in houston
  4. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    we used to use our sidekit stakes all the time with Wylie.
  5. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    Would it work to paint the aluminum black and touch them up right before you go in? They probably wouldn't even notice?
    SHC Thanks this.
  6. dirthaller
    dirthaller Road Train Member
    1,015
    11,797
    Sep 22, 2011
    Coloratah
    Im loading pipe tomorrow and the broker insisted on steel. We will see in the morning.
  7. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    kind of defeats the purpose of pipe stakes, buy using aluminum I take it none you run a chain and binder around the bottom the pipe stakes???
    379exhd Thanks this.
  8. MJ1657
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    The one time I used mine I did.
  9. MrEd
    MrEd Road Train Member
    2,196
    2,836
    Sep 2, 2011
    Winfred, SD
    I thought the point of pipe stakes was to ensure the load stayed on the trailer during loading and unloading. Using steel ones, you may crack a stake pocket, but you won't crack your skull. I think I'd rather crack a stake pocket. We all know how much use them highly regarded plastic hardhats would be. Of course the whole issue would be resolved with more careful forklift operators to start with.
  10. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    Actually, you are supposed to run the chain and binder between the second and third row as that is what causes the pipes to flex and break welds.
    379exhd and MJ1657 Thank this.
  11. MJ1657
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    When I loaded my pipe the guy said to lay the chain on the deck, loop it around each pipe stake then take up the slack with a ratchet binder. He said it would stop my stake pockets from being ripped out if the pipe let loose. I can see where a chain up a couple rows would work good.
