Aluminum or steel flat deck trailer?
Discussion in 'Ask An Owner Operator' started by solo soldier, Dec 4, 2008.
  1. solo soldier
    solo soldier Bobtail Member
    4
    Dec 4, 2008
    edmonton, alberta
    Okay, I'm new to this forum, not a new driver by no means, and I don't own a truck or a company. But I have a boss that does own a truck and is now thinking of replacing the old tandem 48 foot deck I pull around everyday. I haul from soup to nuts on that deck, and sometimes the weight of what ever, is a little more than what should be hauled on that old piece of boat anchor or boat dock. So now, the two of us are looking at a tri-axle highboy, oh and I live in Canada.. and yes the roads suck and so does the winter.
    Question is:
    What is better in the long run, an (all even the frame) aluminum trailer, or a steel frame wood deck trailer (which is my choice)
    The unit I drive is paid by the hour, so getting the most amount of weight on the trailer isn't the issue. Most of what I haul is pretty light but I still get a grunt (heavy lode) once in awhile, mainly bulky stuff. It doesn't matter to me if it is a 53 foot or a 48 foot, the boss figures a 48 tri-axle aluminum, I'm thinking 53 foot tri-axle in steel with sliding axles would be nice... but he is the boss... any advice as to which is the better to own and why would be very much appreciated.
    Backing up isn't an issue here, from super"B"s to quads, its doing it blind folded that scares everyone!
  3. Coonass
    Coonass "Freshy Fresh"
    1,080
    1,179
    Sep 23, 2008
    From my own personal expirence I don't find that one is really better than the other execpt for the aluminum being lighter so you can haul more weight on it.
    I rather pull the aluminum for the reason of weight. The only thing I find, with the aluminum trailer, is that the rub rails bend eaiser (f*#% fork lift operator). My flatbed is all aluminum, and my drop deck is steel with a wood floor.
    If ya'll are buying a tri axle I'm quessing ya'll haul heavy loads, in that case I would go with the steel trailer. It is sturdier for the heavy loads.
    You also said that you sometimes haul more weight than you should, in that case the aluminum trailer would be better.
    Just some thoughts!
    solo soldier Thanks this.
  4. 24valve puller
    24valve puller Medium Load Member
    399
    89
    Sep 8, 2007
    N.E. Oh
    All aluminum, it will beat steel any day of the week, skip the tri-axle unless you are puttint 100k on the deck every day, go with a spread. I hate the way steel trailers with a legal load sag like they have 100k on them. Buy a MAC with the 80k beam and I bet you would never hurt it
  5. lowbudget
    lowbudget Medium Load Member
    428
    110
    Apr 12, 2008
    Bismarck, ND
    How do you haul soup on a flat? Wouldn't it spill everywhere?:biggrin_255:
  6. lostNfound
    lostNfound Road Train Member
    3,506
    2,269
    Jun 28, 2007
    Home of the Stampede
    Can't run spreads here, tri-axles are most common.
  7. solo soldier
    4
    Dec 4, 2008
    edmonton, alberta
    They put the soup in really big bags, kind of tricky on corners, and don't park close to anything hot unless you have another load next to you with crackers.:biggrin_25525:
    Lilbit Thanks this.
  8. solo soldier
    4
    Dec 4, 2008
    edmonton, alberta
    We can't run michican spreads here either, why I don't know, the tandem I'm dragging around now is about as close as you would get to a spread. And we are going with the tri-axle.
    Had a talk with the boss about the aluminum frame, the ones we were looking at are all bolted together, thinking the the bolts being steel and the frame parts being aluminum, sooner or later the frame would loosen up, so I'm pretty sure we are going steel, just easyer and cheaper to fix.
  9. 24valve puller
    399
    89
    Sep 8, 2007
    N.E. Oh
    I wouldn't want a bolt together ritenour, Macs are all welded and it will be a while before anything would ever need welded
