Aluminum end Dump Trailer (Sand, gravel)
Discussion in 'Ask An Owner Operator' started by Abraxas, Sep 23, 2022.
  1. Abraxas
    Abraxas Bobtail Member
    29
    21
    Sep 23, 2022
    Dear owners operators,
    I’m hauling a reefer at the moment, 25 days out, 7 days home. I would like to becoming an owner operator and start doing local run with aluminum dump trailer in Texas. What your experience? I was offered $1800 gross daily and 350 miles approximately a day. But there is no restrictions if you want to haul more (weekends, night shifts).
    How to choose aluminum dump trailer? How to start ? What are your recommendations?
  3. AModelCat
    154,260
    In my experience highway trucks and gravel don't mix well. Usually too lightly spec'd.
    You'll need a wet kit installed on the truck too.
  4. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Depends on TX weight laws ?
    I’d firm up that money because that ain’t bad for today’s market.
    MartinFromBC, Abraxas and MOBee Thank this.
  5. W923
    W923 Road Train Member
    1,296
    3,924
    Feb 28, 2022
    Probably need more information to make any useful recommendations on trailer types.
  6. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    I'd do a lot more checking into the accuracy of those numbers before I worried about a trailer. Sounds like a fairytale to me.
  7. Arctic_fox
    3,861
    19,416
    Sep 16, 2016
    As someone who took a road truck and converted it to a gravel truck this is true. It took a LOT of work to get it to a point where im not breaking stuff on a regular basis and having to swap it out with much heavier duty equipment. I.e shocks, drive line, 5th wheel removing a lot of skirts, adding new guages and switches to use my equipment and all kinds of other nonsense. And a lot of down time and money as well.
    As towards pay i would absolutely say that you can make that much a day......HOWEVER that is before fuel costs and assumeing you haul your ### off all day every day. I can make that much in a day easily sure, but im usually burning almost my entire 14 and nothing has gone wrong....at all including traffic delays sweeping ect.
    A more realistic amount is closer to $1200-1400 a day and that is as an OTR truck.
  8. Abraxas
    29
    21
    Sep 23, 2022
    Hello sir, what details you need for the advice?
  9. Arctic_fox
    3,861
    19,416
    Sep 16, 2016
    Where your hauling, what your hauling, expected number of loads, what bridges around you, type of truck, size of material, how sticky is material are the big ones. As a GENERAL rule though a 38'-42' split axle end dump with a 3 way door (swing, tail gate and coal chute) will cover about 90% of jobs and can do almost everything at least okish though have some pretty strict limitation such as no crushed cars or heavy steel scrap.
    Abraxas Thanks this.
  10. Abraxas
    29
    21
    Sep 23, 2022
    Austin-Houston area, Texas. Mostly sand. I can work 14 hours a day 7 days a week . Which brand of the end dump trailer is good in terms of price/quality (aluminum)?
  11. abyliks
    abyliks Road Train Member
    3,746
    8,694
    May 2, 2010
    ludlow MA
    Trailstar, full frameless, dont even waste time on a full frame and stay away from those POS east trailers.
    most road trucks are fine until ~100, 110k now a days if you don’t suck at driving, I wouldnt haul a Michigan set with them though or anything along those lines, or bring one into a landfill (#### landfills)
    is this paying hourly or ton?
