aluminum 5th wheel
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cominghomesc, Oct 3, 2013.
  1. cominghomesc
    cominghomesc Light Load Member
    276
    117
    Apr 20, 2010
    sc
    Specing out some new trucks for a dedicated customer and weight is an issue anybody have one and do they last?
  3. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Where are you trying to be on the tractor tare?
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    i drove a truck with one before and it seemed to be getting rather chewed up in a short period of time, i was running the truck in a lot of off road conditions however. in a otr application they may do better.
  5. chalupa
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    That was my point EZ but he never answered the tare question. It's a forbidden area in my book. I would find my pounds elsewhere. I will never compromise safety for profit and that's what this is.......
    JMO
    Oh yeah, drivers, if you need a fifth wheel, buy Holland !!!! They fail closed...huh? What? yep sure do. This gives you a almost zero chance of a disconnect....in fact just the opposite, if it fails, you cannot unhook.....
    JTF...
    trees Thanks this.
  6. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    no issues with the locking mechanism but the top of the plate seemed to be wearing rather quickly and had gouges in it from small rocks sticking to the grease and working its way between the 5th wheel and the trailer.
  7. calambert
    calambert Bobtail Member
    8
    I STRONGLY AGREE ALUMINUM is far to Brittle if cast and far to weak if machined. I can't imagine anybody wanting one. What's next Rubber Bands for Windshield Wipers
  8. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Are they willing to also discriminate against heaver drivers and not hire any over 180 lbs so as not to add an additional 100 lbs "needlessly"? Aluminum 5th wheel ... just doesn't seem right to save maybe a 100 lbs. Then, you've got steel and aluminum in contact somewhere. That rarely works out well over the long term.
  9. rollin coal
    rollin coal Road Train Member
    13,080
    25,852
    Mar 29, 2008
    TN
    I doubt they're weaker just likely more maintenance intensive. You'd have to degrease and clean it weekly maybe more if a lot of dropping/hooking was going on. Mine gets that every two or three weeks. Ideally would probably work best greaseless with teflon on the top plate.
    Cetane+ Thanks this.
  10. mikec265
    mikec265 Medium Load Member
    379
    188
    Oct 25, 2009
    Dumbed Down Land, WTF
    Maybe you can find some aluminum tires, studs and lug nuts......
  11. cominghomesc
    276
    117
    Apr 20, 2010
    sc
    Ok a little more info I. Should have posted before. The trucks are going to be kw t680 day cabs we are taking over a private fleet moving scrap metal. It will be a lot of drop and hook. Leasing company I am using told me about them but they do not ave any real world experience with them. Just wondering if they ate worth the hassle and durability
