alternator putting out 16 volts
Discussion in 'Volvo Forum' started by ecook74, Dec 29, 2020.
  1. ecook74
    ecook74 Bobtail Member
    13
    6
    Aug 31, 2017
    Good evening all. My 2007 Volvo is putting out 16.1 volts at times and the "light control module is in high voltage mode" indicator comes on. And a message about the fog light comes on as well but the fog lights are unplugged. The alternator is a 3 wire 34si so I cant run a jumper wire. Any suggestions on what to do? I have cleaned all grounds and terminals.
  3. AModelCat
    154,278
    Get the multimeter out and start diagnosing.
    I'd start with checking the voltage right at the alternator and then right at the batteries. Should be very minimal difference between the 2.
    I'm not the most experienced with Volvo but a lot of newer trucks have a remote sense wire that runs from the alternator to the batteries. If you've got that wire I'd check it too since a poor connection on that wire can fool the alternator into thinking the batteries have low voltage.
    Shawn2130 Thanks this.
  4. salim patel
    salim patel Bobtail Member
    40
    6
    Nov 15, 2015
    I had same problem with 2007 Volvo few years back I ended up changing the cluster .the gauge on deshbord went bad if u check voltage at aulterneter it will be correct.
    loudtom Thanks this.
  5. ecook74
    13
    6
    Aug 31, 2017
    Thanks for the repiles
  6. bad-luck
    bad-luck Road Train Member
    3,247
    5,945
    Nov 16, 2013
    Baltimore, Maryland
    Sounds like the voltage regulator in the alternator went bad, and you need a new alternator. Check the output at the alternator, if its 16 then the alternator is your problem.
  7. ecook74
    13
    6
    Aug 31, 2017
    When I check the volts at the alternator it reads good(13.8 to 14.2). But thats the same reading on the dash at that time. I try to pull over and check the alternator everytime it goes high on the dash but by the time I get under the hood, the volts start to drop. It the regulator is bad, should I get a bad read from the alternator all the time?
  8. salim patel
    40
    6
    Nov 15, 2015
    Change or repair instrument cluster your problem will be solved.i suggest u u buy new deshbord from Volvo dealer. It will outlast your trk. Repair will not guarantee . because other things will go wrong with it buying used same problem.cluster gauge gone go on you tube u will find video on how to repair replace it
  9. ecook74
    13
    6
    Aug 31, 2017
    OK thank you salim patel
  10. vangtransport
    vangtransport Heavy Load Member
    863
    2,837
    Apr 14, 2009
    Are you setting the RPMs higher when you're parked to try & duplicate your RPMs when driving?
  11. ecook74
    13
    6
    Aug 31, 2017
    Yes I am raising the RPMs while parked but the volts doesn't go high on the dash or at the alternator. The volts are between 13.8 and 14.2. The volts only move to 15 and 16 while driving.
