alternator overcharging
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Jeet, Feb 25, 2011.
  1. Jeet
    Jeet Bobtail Member
    24
    4
    Jul 17, 2010
    I have 2007 volvo 780 with cummins isx, my alternator starts overcharging when driving in rain or wet pavement. I have replaced alternator twice, replaced batteries twice as well in last 6 months ( at dealers). Today this problem started again, this only happens during conditions, it will start charging normal as soon as i get into dry condition. I have no idea what is causing this? any help will be greatly appreciated. Thanks in advance.
  3. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Overcharging is usually a faulty voltage regulator on smaller vehicles. Not sure about a big truck.
  4. bulldozerbert
    bulldozerbert Medium Load Member
    622
    240
    Oct 5, 2008
    Ontario
    we have had our fair share of troubles with altenators on our ISX as well...............
    will be watching this thread
  5. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Why do you say it's overcharging? Because the gauge moves higher? Are the batteries overheating and swelling?
    You really need to put a voltmeter to it and get the battery readings engine off, engine on dry weather, engine on wet weather.
    Since it's a wet weather thing, you might have a direct short that's not even related to the batteries or alternator. Take two exposed wires next to each other or a leaking connector, a little water and you have a serious battery drain where the voltage regulator starts putting the juice to her to compensate the robbed voltage.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Usually Voltage regulator, but simetimes connections of Voltage regulator to alternator (ground connection usually.
    WHat brand is Alternator? Volvo used different alternators with different problems. If it si Mitsubishi it is very difficult to find parts.
  7. notarps4me
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Wish I would have thought of that....:biggrin_25522:
  8. Kanu
    Kanu Bobtail Member
    42
    5
    Jan 23, 2017
    Did you solve this problem
  9. Daw1234
    Daw1234 Bobtail Member
    5
    5
    Aug 25, 2017
    Had similar issue 2015 prostar w isx. Intermittent voltage surge to 15+ voltages. Started in desert climate. I thought maybe road salt had dried out inside alt. After became more frequent replaced alternator. V regulator is internal to it. Problem solved. Now 6 mo later V has dropped to 13.3 after brief surge to 13.8 after start. Any ideas? Batteries are AGM type 1 yr. Old.
    KB3MMX Thanks this.
  10. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    First things first. Clean all your battery connections at batteries, alternator, starter and frame and engine grounds. Prostars have their own cable that feeds the cab. Make sure the main cube fuse at the batteries is clean and the mega fuses at the firewall are clean and tight. Some Prostar systems have a secondary low voltage battery cut out relay mounted in behind the battery box. They are yellow in colour and just love to corrode.
    Daw1234 Thanks this.
  11. me myself and I
    me myself and I Heavy Load Member
    731
    312
    Oct 5, 2009
    vernon hills,Il
    I had a same problem, but only after replacing alternator. Twice. Then after a while it settled down. Go figure
