Allen Lund CO is lying scum
Discussion in 'Freight Broker Forum' started by MayaLogistics, Feb 24, 2021.
  1. MayaLogistics
    MayaLogistics Bobtail Member
    9
    9
    Dec 22, 2020
    They act all nice and #### before you get that load. After, they show their true side, which is ugly lying douchebags.
    All drivers out there, double and triple check weight. ALC will lie. Im not kidding.
    Plus their rates are cheap. Im never gonna move their loads ever again.
    jason6541 and OldTruckerGirl Thank this.
  3. mjd4277
    mjd4277 Road Train Member
    13,882
    41,450
    Oct 4, 2015
    Fitchburg,MA
    Where’s the company based out of?
  4. Eddiec
    Eddiec Road Train Member
    2,191
    3,358
    Feb 2, 2015
    They are brokers
  5. MayaLogistics
    9
    9
    Dec 22, 2020
    the main HQ is in CA but they have branches all over the states.
  6. JimmyTwoTimes
    JimmyTwoTimes Medium Load Member
    393
    996
    Aug 23, 2019
    Talk us through what happened here, we need more to go off of than they are ugly dbags. Did you show up to the PU and the supposed 20,000lbs load weighed 44,0000?
  7. MayaLogistics
    9
    9
    Dec 22, 2020
    30,000lbs but then we found out it was actually 46,000. I would've never even called or inquired if I knew it was over 46,000 lbs. Why did I have to go to PU to find that out? Then I call the broker, and he wasn't sorry about it at all.
  8. 86scotty
    86scotty Road Train Member
    4,373
    11,589
    Aug 27, 2017
    Appalachia
    That kind of stuff happens all the time. Is that all you've got? Lots of times big brokers don't even have accurate info on what they're moving. They should but they don't. Sometimes they were lied to as well.
    If it's over your max tell them to remove some and negotiate with broker before you leave the pick up.
  9. JimmyTwoTimes
    393
    996
    Aug 23, 2019
    Yeah based on the weight difference I don't think they lied to you. A lot of TMS allow the user to duplicate a prior shipment and will use the same weight from whatever load was duplicated in the system, so it's possible someone made a mistake. Alternatively they got bad info from the customer and didn't realize it was 46k in weight.
    There just isn't a good reason to lie to the carrier about the weight, especially when it's over 45k. You most likely won't be able to scale gross and it will be a huge PITA to work through the situation.
    They should have offered you a TONU though.
    Dino soar, Dave_in_AZ and 86scotty Thank this.
  10. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    TONU deserved absolutely.
    Still, if it is only $150, they might as well shove it up their ###.
    46K should be all right to scale for a standard dry van and tractor with sleeper.
    Pragmatically, I may or may not want to stay on that load depending on how lucrative it was and how the broker would want to appease me.
    PPNLE, Dave_in_AZ and JimmyTwoTimes Thank this.
  11. 86scotty
    4,373
    11,589
    Aug 27, 2017
    Appalachia
    Joe, don't you drive a Volvo? My 780 with a Great Dane dry box will not scale over about 43,500. I have a small deer basher and a truck bed tool box. I dunno, maybe it's my enormous cajones that put me over max?
