2 questions...
Question 1...I'm not new to this, but i am new to owning my business. I am intrested in hauling cars from Rail Yards and Boat Yards and delivering them to Dealerships. I know of Fleet Car, Central Dispatch, and United Road. Is there any other Logistic Companies that hire independent car haulers up and down the East Coast???
Question 2...Is the law changing to where we need CDL's? If so which states please.
Thank You
All Wedge Trailer & Car Haulers
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by jham1024, Aug 30, 2016.
Go get a job with one of those companies to learn the business first. The knowledge you gain will be invaluable. Then you will know the questions AND the correct answers.
Viceroy1 Thanks this. -
Oh and don't even consider trying this without a CDL. It's hard enough to make it anymore so don't limit yourself even morebrian991219 Thanks this. -
As for the CDL, no laws have changed on that front since the CDL was introduced in the late 80's, just more enforcement officers are noticing pickup trucks and wedges. Most likely you will need a class A, at least if you want to be able to haul enough weight to even think about making money. In a nut shell, any combination over 26,001 pounds with a trailer greater than 10,001 pounds gross weight rating will require a cdl. Example, 15,000 pound gross rating on a F-450 with a Kauffman wedge at 12,000 pound rating will need a class A, regardless of the registered or actual weights. Also you will need apportioned plates, IFTA (fuel tax), NY HUT (if you run NY), USDOT number, MC Number/Authority, Unified Carrier Registration (UCR), drug testing program, and individual state authorities if you do point to point work within any state, especially PA, NY, NM, and many others.
As for the brokers, those are the easy to find bigger ones, and not to sound like an arse, but work is tight right now for all of us carriers so don't expect any of us to give up our preferred vehicle shipper sources, we like to keep them closely guarded. You can also check the bigger used/wholesale brokers like Cars Arrive and Ready Logistics, they have lots of work for smaller carriers with smaller trucks. -
Brian Is it possible to get a CDL A without going to school? I want to run a ram 3500 and a 4 car wedge
I never went to a school, took my CDL exam back in 92 at a third party test site in Pennsylvania for my class B, then about 8 months later I borrowed a dump truck and trailer and took my A. My younger brother did the test with a borrowed truck and our dad riding with him, from getting his permit until passing the road test was two weeks back in 1994.Ziggy319 Thanks this. -
Thank you for the info. I am sure i can study and pass the test. I am not an idiot. Very intelligent actually. One other question though. For a dually and a wedge do i need an A or a B? and what is the difference?
Thank you
Dually and wedge will be a class A with air brake restriction, and most likely auto trans restriction since it is rare to find a manual trans dually these days. What makes the difference from no cdl at all to the class A is the trailer gross weight mostly.
If you kept your total gross combined weight ratings of the truck and trailer under 26,000 pounds then you will not need a cdl at all but this limits your payload greatly. The key is the weight ratings, not the actual weight or registered weight as many people confuse that.
For a class A you will need a trailer with a gross weight rating greater than 10,001 pounds (most 3 car wedges are 14,000 gvwr or more) and a power unit with a gross vehicle weight rating high enough to make your combined rating over 26,001 pounds. Typical dually is 15-19,500 gvwr so lets say 15,000 truck and 14,000 trailer you are 29k with a trailer over 10,001 and will be a class A.
