All lug-nuts snapped. Wheel came off?
Discussion in 'Experienced Truckers' Advice' started by greenllll, Oct 2, 2011.
  1. greenllll
    greenllll Light Load Member
    52
    31
    Oct 28, 2010
    Albino, TX
    What could cause all of the lug-nuts to snap in half, letting a tandem wheel and braking mechanism roll off of a truck, leaving behind just a brake-pad, snapped lug-nuts, and an axle?
    Could the brakes have over-heated and caused the steel in the lug-nuts to lose integrity? If that was the case, there should have been loss of braking action, but there wasn't, and while there were a lot of big hills, the jakes did 95% of the braking. Yes, rain may have contributed too, and for some reason, the same thing happened to someone else at the same location.
  3. bulletproof77
    bulletproof77 Medium Load Member
    557
    541
    Oct 2, 2009
    Victorville, CA
    Over-torqued...rust, piss poor maintenance. Driver error in not checking lug nuts during pre-trip...Hot brakes and rain ? No, wishful thinking..And I doubt the LUG NUTS "snapped in half"....Don't you mean the WHEEL STUDS ? You know those things the lug nuts SCREW onto ..?? And for the "jakes to do 95% of the braking "...you know this how ??
  4. Ridgerunner665
    Ridgerunner665 Road Train Member
    2,129
    1,037
    Apr 27, 2009
    Over torqued...or left loose...either one will lose a wheel eventually.
  5. bulletproof77
    557
    541
    Oct 2, 2009
    Victorville, CA
    Driver error..bad pre-trip..
    wis bang Thanks this.
  6. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Over tightened, Theres no way a driver can tell if the lugs are over tightened on a pretrip. Bad maintenace.
    F1EXPRESS, keepitsimple and jlkklj777 Thank this.
  7. Old Man
    Old Man Road Train Member
    4,597
    13,469
    Apr 3, 2009
    Oklahoma City, OK
    Most times this is caused by LOOSE lug nuts, no pre trip. Was a common problem when we had 2 piece lug nuts. Did this truck have uni mount wheels or old style 2 piece lugs?
  8. Everett
    Everett Crusty Shorts, What???
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    :biggrin_25523: And i laugh at myself every time i see this quistion in the haz mat test, if the wheel is hot, the driver must take the wheel off and put in the safe place, one if that wheel is that hot , there no way i'm gonna manhandle a hot wheel, two, i dont have the proper tools too take a wheel off, :biggrin_25512: anyway back too the quistion at hand , two erro's here, one is a fail'ed pretrip , mayby, you can do a top nocth pre-trip that morning, then that afternoon the wheel fall's off, due too bad roads , ect, truck shake and stuff so bad sometimes, it could be bad maitance, but if this was a mega carrier i dought it, sound's like they didnt use the right color stick's on the wheel stud, a color stick is a pre determine color for tork on a tork wrench , and might got them to tight , stressing the wheel stud, :yes2557: now i go find my big book , too learn how too spell again , so sorry about that :biggrin_2556:
    johnday, Big Don and skellr Thank this.
  9. jlkklj777
    jlkklj777 20 Year Truckload Veteran
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    This happens when shops do not use proper tightening technique when torquing a wheel. That means using a "torque wrench." Most shops simply use the air impact gun to tighten the lug nuts onto the studs which could actually stretch the stud depending on the guns setting.
    There is also a statement on tire repair work orders recommending the driver stop 50 to 100 miles down the road and have another shop check the lug nuts and tighten as needed.
    The only way a driver would (or could) detect a loose lug nut is if he sees rust streaks on the rim from the stud holes. If you see rust streaks then you should have the wheel removed by the shop and the studs inspected carefully for stretched threads or cracks. Have the wheel replaced and be sure they use a torque wrench to tighten the lug nuts uniformly.
    All it takes for a wheel to come off is to have 1 stud fail. Any movement between the rim and the studs will cause the other studs to fail until all studs finally break and then the wheel goes flying.
    UFO and Big Don Thank this.
  10. okiedokie
    okiedokie Road Train Member
    11,675
    84,490
    Jun 13, 2011
    PNWET
    Was the holes in the wheel wallowered out? Loose nuts. Snapped clean over tightened. Loose nuts are detectable when driving and pre-trip.
  11. KajunTankerYanker
    KajunTankerYanker Light Load Member
    122
    32
    Aug 11, 2011
    GrandLake,Louisiana
    90% of the time when this happens you had loss lug nuts, the flexing broke the ones that weren't
