Alignment issue -- truck pulling to right
Discussion in 'Volvo Forum' started by JerryD13, Apr 8, 2019.
  1. JerryD13
    JerryD13 Light Load Member
    169
    126
    Oct 17, 2016
    Alignment issue -- truck pulling to right -
    I changed out leaf spring bushings last week - they aligned the truck with new tires.
    now the truck is Pulling to the Left - I was told .. to balance the right Tire - I did that
    and it improved but still pulling -- left *** the TA guy said he put 6 OZ weight on the right tire.
    The Steering whee - also is pitched about 5% - not perfectly straight.
    if i let go of steering wheel it will go right right away.
    ** The original work was done in Denver - I am in Texas now, so have to do further work elsewhere.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    That's a pile of BS babble from that mechanic.
    Most all vehicles from 18 wheelers on down to little cars come out of the alignment shop at factory numbers and assuming wheels and tires are balanced etc there is no pulling.
    I actually am trained on the old Alignment rack which is manual and involves some paperwork etc to doodle stuff. I have forgotten most of it. But I do know that most anything when aligned properly as intended by factory settle right down and behaves without pulling.
    If anything the vehicle should try to come back to center when horsed out of line. The old steering of big rigs was the same. You would spin it for a left turn and let it go. She will go right back to straight and center coming out of the turn. Today's trucks don't have that usually. Too nuetrual and need holding hands all the way around.
    I am going to have to willfully stop typing, that babble from that mechanic is such tripe... I bet it will take 10 pounds of lead sitting on his foot to make him be straight.
    Rounded_nut Thanks this.
  4. Rounded_nut
    Rounded_nut Light Load Member
    92
    107
    Feb 25, 2018
    Find a shop that does not use a computer, could be simple like your drives are gapped on the road side. Anecdotal but my guy got to test out a new bee line computer alignment, put it against their old way of doing it and the machine was off.
    Snailexpress and JoeyJunk Thank this.
  5. Freightliner Classic
    Freightliner Classic Light Load Member
    108
    98
    Dec 17, 2018
    Rome GA
    Find someone that doses it the old fashion way with a tapemessure the computers are crap
  6. dynamite
    dynamite Light Load Member
    67
    70
    Jun 2, 2018
    Wisconsin
  7. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    I wouldn't trust TA technicians , most are inexperienced young mechanics working there just to get some experience, got many problems starting from a basic oil change, had to tow the truck to Volvo .
    KB3MMX Thanks this.
  8. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Correct. Not a balance issue. Make that 20 lbs on that so called "mechanic's" foot.
    KB3MMX Thanks this.
  9. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    The only time I ever had a truck pull left was when I had cheap Chinese steer tires put on. We ended up taking the left steer tire and flipped it on the rim, truck ran straight, I put about 100k on them and got a good set of Michelins.
    KB3MMX Thanks this.
  10. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    nothing to do with balance this is just bs they say make sure all axles are sitting straight drives will affect steer more than a lot of people think they do, make sure you do a 3 axle alignment if there is anyone that still does it old fashioned way, although that will be hard to find.
    KB3MMX Thanks this.
