Algae in the tanks, best way to get rid of it quick?
Discussion in 'Volvo Forum' started by Sdatruckinginc, Jan 20, 2019.
  1. Sdatruckinginc
    Sdatruckinginc Bobtail Member
    46
    20
    Jan 18, 2019
    How can you tell diff between carbon and algae growing in tanks if I read right both appear black
  3. Coolbreeze
    Coolbreeze Light Load Member
    199
    115
    May 13, 2008
    Atlanta, Ga.
    I always heard to goto a place that sells marine supplies. Those boats with diesel motor get it often. But if it’s a Cummings motor, I think they have there own product for that.
    I glide 47 and Sdatruckinginc Thank this.
  4. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,210
    Feb 25, 2016
    I-20 LOUISIANA
    Search killem. I heard that’s about as good as it gets
  5. Ok big boy
    Ok big boy Light Load Member
    77
    78
    Jan 22, 2014
    All I have is old information. You can take it for what it is worth. I used the powerservice in the green bottle. If a guy had access to a marine dealer near a coast or great lakes where diesel's are used in marine applications, there might be something better.What you may be seeing is Asphaltene - Wikipedia. I owned a 2008 Volvo with D13. I had the same issue.It was showing up in the Davco filter. Volvo guy's told me the temp of the return fuel line was plus 130F. That was the culprit I was told.I hope this will help you. Check out asphaltene in a search.
    Coolbreeze and Sdatruckinginc Thank this.
  6. Sdatruckinginc
    46
    20
    Jan 18, 2019
    Read up a little more not really algae just called that really just sludge from fuel breaking down and Killem seems to be best product out there that I found so far just haven’t found a dealer near me still lookin I’m in Texarkana so not a lot of choices
  7. Sdatruckinginc
    46
    20
    Jan 18, 2019
    We’re you losing power randomly or was it a constant what was your engine doing I lose power random it comes and goes no pattern or trigger
  8. Sdatruckinginc
    46
    20
    Jan 18, 2019
    Just found out oReilly’s auto can get it be here tues morn fingers crossed
    I glide 47 Thanks this.
  9. Lyle H
    Lyle H Road Train Member
    1,289
    2,931
    Apr 16, 2014
    Ok big boy is correct.
    Algae and asphaltenes are two different animals and need to be treated accordingly.
    Cummins (Fleetguard) makes the asphaltene treatment. Killem will work for the algae.
    If you’re not sure what you got, I believe you can get test strips that can help pinpoint the culprit.
  10. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    Asphaltene and 'algae' aren't the same problem.
    The biocides work for microbials, all contain borax, were considered expensive by some.
    It often developed in storage tanks with water not being drained, the microbes grew right where the fuel and water line was, and if you picked up fuel with it, it was bad news, bad because of filter plugging, and the microbes contained molecular water, enough the make a misfire or mess up an injector.
    I picked up a batch at a preferred fuel stop and didn't make it 30 miles, then fought it the rest of the winter, we had 2 trucks in the fleet that both had it, but the people that owned the company wouldn't treat it, too costly,they said and the dealer confirmed the problem by connecting an outside tank with clean fuel which cleared up the misfiring.
    Both early ISX, both had very hot fuel returns, and were idled as company policy when temps were below 20 degrees. It cleared up in the one I was driving when the weather got warm, and I helped it by drawing the tanks down pretty far before refilling with fresh fuel.
    I quit getting fuel at that preferred stop, too.
    Asphaltene is a breakdown of fuel caused by too much idling and return fuel, the particles bond together producing plugs of goo, it's not slimy like the microbes, but it tends to plug passages other than filters, that was a ddecIV 12.7 Detroit also idled per company policy.
    Completely drain the tanks and steam clean is one way, I heard from an older mechanic that rinsing with gasoline would work. There is a bad bacteria called pseudomonas that lives similar to the diesel algae in gasoline.
    I'd use the biocides, and carry extra fuel filters, drain water separators often, etc. If it was mine. Haven't had anymore problems with it in about 10 years, 2009 or thereabouts, no more trouble with asphaltene, either.
  11. Sdatruckinginc
    46
    20
    Jan 18, 2019
    When you had probs with it did you have a constant power loss from blockage or would it come and go cause a surging
