Alcohol anti gel
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jeffman164, Nov 11, 2019.
  1. jeffman164
    jeffman164 Medium Load Member
    594
    557
    Dec 4, 2012
    1999 Detroit 12.7. Pre emission . Heard quite a few times that you can use rubbing alcohol as opposed to commercial anti gel to avoid gelling. I would appreciate the help from some old school mechanics what the ratio of ounces of rubbing alcohol to the gallons of diesel to avoid gelling. I've used commercial anti gel products according to the directions and have still gelled up. NOT fun !!
  3. Tx Countryboy
    Tx Countryboy Road Train Member
    1,968
    4,437
    Sep 18, 2019
    Cattleman84Road Train Member
    Forget throwing your $$$ away on them #### fancy anti gel additives... Go get you a case of Isopropyl Alcohol...
    See post below.
  4. Tx Countryboy
    1,968
    4,437
    Sep 18, 2019
  5. Rideandrepair
    17,197
    55,775
    Aug 8, 2015
    That Detroit shouldn’t gel up, as long as your running. I’ve used 90% alchohol, half bottle in each tank. Mainly for protection against water, I thought it evaporated, always use any of the others,Howe’s, PS, or ? in southern fuel, have never gelled up.
  6. Tx Countryboy
    1,968
    4,437
    Sep 18, 2019
    @Cattleman84 runs in some cold stuff. So I take his word for it.
    I gelled up in montana with howes one time at -22°
    Cattleman84 and Rideandrepair Thank this.
  7. Rideandrepair
    17,197
    55,775
    Aug 8, 2015
    Reminds Me, I need to get some. Good for ice in air lines too.
    Cattleman84 Thanks this.
  8. Tx Countryboy
    1,968
    4,437
    Sep 18, 2019
    Shop used to swear by howes till trucks went down.
    Rideandrepair Thanks this.
  9. Cattleman84
    Cattleman84 Road Train Member
    9,869
    70,289
    Nov 1, 2017
    The Sticks, Idaho
    Certain anti gelling products will give emission systems fits also... And they can play hell with bunk heaters to.... 90% or better Isopropyl Alcohol is safe for all diesel engines and heaters.
    Also... In the post above where @Tx Countryboy quoted me, I must have been tired when I posted it cause the mix ratio is wrong... I use 8 ounces per 100 gallons, southern fuel I double that to 16 ounces. 1 quart treats 400 gallons.
  10. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    If I use anything it is howes, or plain old gasoline. Howes will not do anything as far as dispersing water, water will still collect and freeze in the filters if it is present.
    Do not use rubbing alcohol in your air system, unless you want to replace all the air valves, been there and done that. Airline antifreeze is cheaper anyway.
    D.Tibbitt and Rideandrepair Thank this.
  11. Rideandrepair
    17,197
    55,775
    Aug 8, 2015
    I’ve used it without problems, however I usually buy the “conditioner” on sale in springtime. Just used half a bottle, I’ve had for a while.Cleaned out lines and tanks before putting on a new air dryer. The bottle was all blown up, like it’s ready to explode, Lol. Main ingredient on label? Methyl alcohol.
