airbag repair/replacement
Discussion in 'Trucks [ Eighteen Wheelers ]' started by amstruck, Mar 6, 2009.
  1. amstruck
    amstruck Bobtail Member
    33
    Oct 25, 2008
    fort worth, tx
    I am wondering if anyone knows if repairing an airbag is fairly simple, and if so how?:biggrin_25512: Also about how much it would cost to let the dealer do it? i have an 05 western star 4900ex. I got hung up pulling out of a dock on an incline and now the thing wont air up! stuck my hand in there and it seems that it may have come off of the "thing" that it sit on. Thanks in advance for any advice!!!
  3. kelgar50
    kelgar50 Medium Load Member
    334
    218
    Feb 1, 2007
    Bakersfield,CA
    I just changed the air bags on the back axle of my freightliner last weekend and it is very simple.I had not changed bags on a big truck before but including the time to dig out the tool box and cleaning up afterwards and washing my hands it was about 45 min.
    If your airbag is not torn or does not have a hole in it you could take it off and try to get the bag reseated right and put it back in.But you have to have a hyd. jack or a 4x6 wood block to put between the axle and frame to keep the bag free when you dump the air in the bags.
    amstruck Thanks this.
  4. amstruck
    33
    Oct 25, 2008
    fort worth, tx
    that sounds like my solution thanks alot!!!
  5. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I have a KW 8 bag suspension that I am constantly changing bags on (they are old and cracked, I have almost all of them chaged out). I have a permantly mounted box on the truck, so I have to do it all from under the truck and it is still a pretty simple job.
  6. candab
    candab Light Load Member
    90
    8
    Aug 5, 2007
    McKinney, TX
    I've had to put some new bags on here & there and it cost about $500 parts/labor each time. Labor seemed really high.
  7. kwforage
    1,047
    472
    Jun 3, 2007
    Wisconsin
    WOW! I realize all bags are different, but mine are only $100 per bag, and I do it in about an hour. Was that at the stealership or an idependent shop?
  8. candab
    90
    8
    Aug 5, 2007
    McKinney, TX
    Tall bags, put on at an International shop. The bags I needed ran about $230, I believe. Don't let my boss see this thread, he'll have us start doing it ourselves!
  9. amstruck
    33
    Oct 25, 2008
    fort worth, tx
    you hit it right on the button. took me a couple 2x4's and a socket set out there on got it re-seated.....thanks again,:biggrin_255:I think u save me at least $200
  10. kelgar50
    334
    218
    Feb 1, 2007
    Bakersfield,CA
    Not a prob. with the the way things are these days it is worth it to try and do somethings our self.
    Glad it worked out for you.
  11. droy
    droy Heavy Load Member
    828
    159
    Jun 11, 2008
    Iowa, LA
    Like kwforage, I have had a couple of trucks with the 8 bag system, not a big, nor expensive job to R & R them. I had a section of airline rigged up that would let me to bypass the air to the bag I wanted to replace, allowing the others to air up. This would eliminate the need to jack the frame up to R & R the bag. If you do this, be sure to block the frame to keep it from falling down to the stops while your hands are in there, "just in case". Would hate to hear that anyone finished the job with less fingers than when he started.
