Airbag pressure
Discussion in 'Volvo Forum' started by wspencer, Mar 5, 2023.
  1. wspencer
    wspencer Bobtail Member
    Helping out my brother on his 2007 vln 670.
    He is getting constant 75psi in the front bags bobtail. Anybody know what the standard pressure on the front bags should be with no load? 75psi seems to be really high with no load in my opinion.
  3. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    937
    Jan 11, 2022
    I have no idea what you mean. I'm gonna follow and hopefully learn something.
  4. Neilwhayes
    Neilwhayes Bobtail Member
    30
    25
    Jul 8, 2014
    miramichi nb. canada
    When my pressure went up like this, similar range, it was the leaf spring had broken and the air bag was compensating.
    flood Thanks this.
  5. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Steer axle should be about 45ish empty and 55-60 loaded for best ride... Height adjustment affects pressure of the front bags.. his must be way outta spec
    Magoo1968 Thanks this.
  6. AModelCat
    154,362
    The pressure is whatever it needs to be to maintain the correct ride height. Either its too high up front, its compensating for a worn/broken part or that's just how it is.
    KB3MMX Thanks this.
  7. KB3MMX
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Yes, adjusted correctly at gross wt , it should be between 55-60psi.
    If it's much higher than that the ride height is set too high... A common problem that also negatively impacts the ride.
