Air tanks question
Discussion in 'Questions From New Drivers' started by jterry1556, Dec 31, 2023.
  1. jterry1556
    jterry1556 Light Load Member
    65
    53
    Oct 6, 2022
    I have an international LT and I have never driven one before. My last truck held air pressure but this truck every morning when I wake up both my primary and secondary air gauges are showing 0. This isn’t normal right? For the life of me I cannot find the leak and if there is one I am sure it is on the tractor because I disconnected the trailer to test it. Am I supposed to start with 0 air I never used to?
  3. AModelCat
    154,534
    Yes it has a leak. As long as it isn't leaking out faster than specified in the air brake regulations then it is legal to drive.
    I would still search for the leak, always good to be on top of little things like that.
  4. Short Fuse EOD
    2,747
    8,546
    Jul 29, 2015
    Midwest
    If your hearing isn’t the best, like mine. Spray every connection with soapy bubbles. Outside the truck and inside. Or pay some guy to look for you.
  5. Diesel Dave
    8,528
    23,526
    Jan 20, 2010
    Hesperia, Ca.
    I don’t know why newbies always make an issue out of this. Long as you’re not leaking all your air out in an hour, don’t worry about it. In my case, I have a 2014 Pete, I will lose all my air over night, however, I’ll still have air in a 12 hour period.
  6. 062
    062 Road Train Member
    6,143
    33,182
    Oct 20, 2013
    Those are bad for leaks along the firewall and if it has a Cummins, then check the signal line on top of the compressor.
  7. jterry1556
    65
    53
    Oct 6, 2022
    Thank you for all the responses! I will keep looking for it.
  8. Espressolane
    17,001
    102,603
    Air drier is a prime culprit.
    2Tap and Big Road Skateboard Thank this.
  9. Judge
    84,607
    Fittings around air tanks are bad about leaking too.
  10. Gliding ProStar
    Gliding ProStar Heavy Load Member
    860
    6,132
    Nov 12, 2016
    Waxahachie, Texas
    As the other posters have stated, check for loose connections with a spray bottle of soapy water. Inspect the air lines that pass through the firewall/bulkhead. These lines have a tendency to leak due to the cab movement and vibrations while driving.
    Inspect the rear suspension air bags for leaks. Look at the base of the air bags and check for any abnormal wear in the rubber.
    If the truck is equipped with a Cummins X15 inspect the main air line at the top of the air compressor. Also, inspect the air drier.
    Inspect the cab air ride system and see if the leveling valve is allowing air to escape.
    There are several things that could cause the air to escape while sitting overnight.
    How does the air system when you first start the truck with zero air in the system? Does it take a long period of time for the system to reach the governed pressure?
    Once the system has reached the governed pressure and you hear the drier purge, how long will the system hold air before the air compressor engages again to refill the system?
    Big Road Skateboard Thanks this.
  11. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Push fittings on modern trucks suck for holding air long term..
