air tank pressure high pressure
Discussion in 'Ask An Owner Operator' started by claydupont, Aug 3, 2020.
  1. claydupont
    claydupont Bobtail Member
    Aug 3, 2020
    this is on a international single axle dump truck. air tank 1 is going to a high pressure, 150 plus. tank 2 is around 120. any ideas on why tank 1 is going to such a high pressure? it just started doing this
    blairandgretchen Thanks this.
  3. blairandgretchen
    13,212
    70,201
    Dec 9, 2011
    South west Missouri
    Adjusted the governor?
    I’m guessing secondary air systems are leaking enough to only reach 120, while primary tank holds the governed pressure.
    What pressure was ‘normal’ prior?
  4. claydupont
    Aug 3, 2020
    normally they both went to 120. i haven't made any changes and now #1 goes to 150 plus. i did accidentally pull the lever on right hand of steering column " not for braking"
  5. blairandgretchen
    13,212
    70,201
    Dec 9, 2011
    South west Missouri
    Then there is guage accuracy to be considered.
    SmallPackage and roshea Thank this.
  6. 062
    062 Road Train Member
    6,141
    33,150
    Oct 20, 2013
  7. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Completely drain the system and see if #1 also returns to zero. I would say a bad gauge. They are only mechanical and do fail. (you didn't mention your model or year). If the #1 gauge doesn't return to zero when empty, it is just a bad gauge.
    SmallPackage and 062 Thank this.
  8. SmallPackage
    5,273
    16,440
    Dec 20, 2019
    Marion Texas
    Like @blairandgretchen and @Heavyd I say bad gauge. There should be a safety ”pop-off” valve that releases the psi if it gets too high. Not sure what International spec would be but I’d think if it truely got above 140 it should pop off at that or at most 150.
