Air scales with 2 leveling valves question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dziubak, Aug 10, 2023.
  1. dziubak
    dziubak Bobtail Member
    16
    6
    Dec 27, 2012
    I am thinking of putting in one of those teltek air scale gauges in my truck. I have an 8 bag kenworth suspension with two leveling valves. What is the correct way to install the guage to make sure it’s accurate? I’m sure I need readings from both axles, how do I feed the pressure from each axle into one guage without crossing the different air pressures from the two valves? I’ve called teltek and they couldn’t give me a straight answer. It sounded like they were guessing
  3. blairandgretchen
    13,238
    70,566
    Dec 9, 2011
    South west Missouri
  4. FLHT
    FLHT Road Train Member
    1,330
    2,262
    Aug 2, 2014
    I am thinking you may need two gauges. One for each axel ?
    Add the total from the two ??
    Got me wondering ?
  5. JB7
    JB7 Medium Load Member
    649
    913
    Dec 13, 2022
    Laurel, MD
    What about this?
  6. dziubak
    16
    6
    Dec 27, 2012
    I think if I connect the two output sides of the leveling valves, it would defeat the purpose of the two valves and they would both be trying to adjust each other, causing problems
    W923 Thanks this.
  7. dziubak
    16
    6
    Dec 27, 2012
    I was quoted a set that would connect to both axles and use one guage but it was a lot more than I really want to spend on this
  8. OLDSKOOLERnWV
    17,823
    268,711
    You have 2 leveling valves? 1 on each side of truck?
    I have 2 Teltek gauges in the dash with the red digital readout. But I only have 1 leveling valve on KW 8 bag air ride….
    Oxbow Thanks this.
  9. OLDSKOOLERnWV
    17,823
    268,711
    Come to think of it, there is a instruction sheet of some kind in the glove box, I’ll have to get it out later tomorrow and look at it when I get back…
    Oxbow Thanks this.
  10. AModelCat
    154,581
    The old man only ever ran dual levelling valves on his trucks for better stability - levelling valve on each side. He only ever had 1 gauge so it was likely only plumbed in to one side.
    Honestly, just tee into one side and call it a day. Unless you're running a straight truck or a body job with one side significantly heavier than the other the numbers are going to be close enough.
    W923, kylefitzy, OLDSKOOLERnWV and 4 others Thank this.
