air ride seats - educate me
Discussion in 'Trucks [ Eighteen Wheelers ]' started by willeo6709, Apr 25, 2016.
  1. willeo6709
    willeo6709 Bobtail Member
    45
    5
    Oct 26, 2015
    My new to me 2006 Peterbilt 335 has an annoying squeek in the drivers side air suspension. I can't tell if its pins turning in the brackets where they are not supposed to or what the deal is. It says national on the cover on the side, it has a Peterbilt logo embroidered into the fabric of the seat ( that I assume is original). I looked on the bostrom site ( there is Bostrom T915 available locally used ) I can't make heads or tails of what I would need. Most of the seats say they are wider than original, but without knowing how much wider I don't know if it clears the 2 man bench beside it.
    Love the truck but the squeek is something I could do without. How do I tell what I have and what I really need?
  3. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    Lube it.
    KB3MMX Thanks this.
  4. willeo6709
    45
    5
    Oct 26, 2015
    greased up every zerk I could find...... still squeeks. My guess is either bushings are supposed to be around the pins and are long gone or ####s bent and the wrong part is pivoting where its not supposed to.
    so what do I need to learn to replace the suspension or is a whole seat the way to go?
  5. Doing_flatbed_nc
    Doing_flatbed_nc Medium Load Member
    585
    846
    Mar 3, 2016
    Mine squeaks where the leather runs the cab interior
  6. Mudguppy
    Mudguppy Degenerate Immoralist
    1,657
    4,064
    Apr 28, 2014
    Wooley Swamp
    Go to a good truck/chrome shop (ie Iowa 80, etc.) and test drive some of the aftermarket seats available. You (and your backside) can thank me later.
  7. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    a standard width(not wide ride)should fit next to your bench seat. My dad's truck has a 2 person bench seat and he replaced the drivers seat with a regular seat, it's a close fit but it works. Personally I would stay away from a used seat unless the owner got rid of it for a different color/style.
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Used seats are bad news. When ever I changed rigs or got into a new company I usually requested a new seat to be installed because the old ones were losing bolts, arm rests or beat up etc. I pay for a bad used seat with my back day and night. But it's not something you want. Get a new Seat.
    As far as squeaks grease it. Dab some of that 5th wheel grease on there.
    Figures with half the stuff that is done to build a truck, a few squeaks don't matter much unless the antennas are doing a dance. =)
  9. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    It's usually the rollers that dry out in the tracks, try some white lithium and spray the crap outa everything that moves or you think that might move.
    crb, KB3MMX and Bean Jr. Thank this.
  10. Bean Jr.
    Bean Jr. Road Train Member
    5,467
    9,694
    Mar 30, 2014
    White lithium does the trick. I had one and it drove me nuts. I got the spray and sprayed every contact point. Now I'm back to my usual level of insanity.
    lee2442, crb and KB3MMX Thank this.
  11. Dominick253
    Dominick253 Heavy Load Member
    746
    634
    Nov 19, 2015
    Needs new bushings. Seen it tons of times. But I will say after I started riding with the seat all the way down my back has never been better. At least with a road truck air ride seats hurt more than they help me.
