Air Ride Seat Cap
Discussion in 'Ask An Owner Operator' started by Indigojones47, Dec 8, 2019.
  1. Indigojones47
    Indigojones47 Bobtail Member
    18
    Aug 15, 2017
    I’m removing the seat in my 14’ Cascadia to make room for a fridge but I can’t figure out how to Cap my air line AFTER the seat is removed. Any advice is welcomed
  3. wore out
    wore out Numbered Classic
    15,319
    184,959
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Trace line back thru the floor find where the fitting comes out of the tank. Remove fitting install plug. That is the proper way. Bend it over and wrap a zip tie around it is the fast easy way
  4. Saltyoldone
    Saltyoldone Light Load Member
    180
    507
    Jun 16, 2019
    Boise
    Throw a quick connect from Home Depot on there then you have the option of connecting an air hose later if desired.
    FlaSwampRat, PE_T and Rideandrepair Thank this.
  5. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
  6. HoneyBadger67
    2,056
    4,511
    Dec 15, 2018
    Savannah, TN
    Just cap it with a compression fitting and a plug.
    starmac, FlaSwampRat and PE_T Thank this.
  7. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Short piece of hose and a screw with some silicone
    FlaSwampRat Thanks this.
  8. HoneyBadger67
    2,056
    4,511
    Dec 15, 2018
    Savannah, TN
    I tried that...the silicone kept blowing out of the hole.....
    /s
  9. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    An old rusty pair of vice grips and some duct tape otta do it.
  10. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    Any half-decently well-stocked hydraulic shop will be able to give you a fitting for the line and a plug.
  11. Rideandrepair
    17,202
    55,800
    Aug 8, 2015
    I would just make a shorter loop with what you have. Tuck it out of sight, protected. That way it’s there ready to be used in the future, or put back to original.
