Can anyone comment on this? I’m about to spec a new KW and was looking for saving as much weight as possible for more tonnage and was wanting to spec a 13200lb front axle with air bags instead of springs? Does it hurt the wear on tires? Can you keep the axle lined up, etc..? Or can you even notice the difference from a spring not taking ride quality but alignment problems? Thanks in advance?
AIR RIDE FRONT AXLE?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JLT, Apr 30, 2023.
Most steer axle air ride setups I've seen just use a lighter spring with an airbag to help support the axle.
Last Call, Diesel Dave and lester Thank this. -
Know of any major problems with tire wear or alignment?
You need to specifically track down PACCAR owners spec’ing a KW/Pete, as it’s a totally different setup from a Volvo. Zero comparison in ride, as well. The KW air ride is much nicer.
You definitely want the AirGlide 380 rear suspension, if it fits into your operation’s weight rating. The PACCAR rear suspension rides like garbage. -
I’ve been driving a 389 with factory air ride front 13,200. 800,000 on the clock and as far as tire wear……a bad shock is the only problem that is exacerbated by air bags. You can’t run bad shocks!
Can't see how tire wear would be any different, should still be a solid axle like spring ride is.
Last Call Thanks this. -
I think I’m going to go with it, I specked air glide 400 for the weight, but is ag380 better?
I had a steer tire blow out on an 07 columbia with the air ride front axle.
That was fun, not only did the left front tire blow, half the hood, blew the fender off, the tire cap wrapped around and blew the airbag, and also knocked off the brake chamber and the air line.
I called the company and told them i blew a tire and needed a tow truck, dude said you mean service truck?
After i told him the extent, i was towed to joplin freightliner were i waited 2 days to be fixed, which was kinda quick, i thought.
Front airbags are ok, til the unexpected happens.
Still don’t know where that headlight assembly went..Rideandrepair, JoeyJunk, Oxbow and 1 other person Thank this.
