Air purging constantly.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Xenergiserx, Dec 1, 2022.
  1. Xenergiserx
    Xenergiserx Light Load Member
    107
    60
    Feb 2, 2021
    Hello to y’all guys and girl. Yesterday my truck started purging constantly. Air tank kept going passed 120 purged and dropped to 119 then repeat every 30 seconds. I’m on a time sensitive load. What can it be.? The purge valve is not leaking and I can’t find no leakes. I drained my air tank and had some oil in it
    Also last night I stopped to look for the problem the started working normal. Now this morning started again. It’s 29 degrees here ‍♂️ Any clues. Can I bypass can I make it home 2200 miles to fix?
    singlescrewshaker Thanks this.
  3. Raffito
    Raffito Light Load Member
    84
    53
    Aug 25, 2019
    Ingram, TX
    As long as the system does not have a leak( p. Brakes released and brakes applied) and it built pressure 120-125 you can make it. Probably it’s the unloader valve inside the air compressor is stuck. It keep the compressor working constantly.
  4. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Mine was doing the same on my tri axle kept popping off every 20 seconds or so, changed out air dryer filter and all was good.
  5. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Make, model and year truck?
    I'd guess a leak in the signal line between dryer and compressor. It tells the compressor when to load and unload. If it has a leak the compressor will cycle on and off constantly.
    Not really gonna hurt anything to run that way. Might take a few miles off compressor
    Raffito and singlescrewshaker Thank this.
  6. ABiceRoads
    ABiceRoads Bobtail Member
    7
    Apr 30, 2018
    It happened to me. It was leaking from the fitting on Air dryer in cold ND weather.
  7. Raffito
    84
    53
    Aug 25, 2019
    Ingram, TX
    You are correct, did not think about air governor mounted to the air dryer.
  8. Animosus
    Animosus Heavy Load Member
    708
    2,774
    Dec 7, 2015
    SE Wyoming
    We had an issue with one of our trucks with an AD-9 dryer. It was purging every 10 seconds. There is a little plastic check valve with an o-ring on it behind the fitting coming from the governor, lubed it up and replaced the o-ring and it has been fine.
    jbaxter68 Thanks this.
  9. MTMAUS
    MTMAUS Light Load Member
    222
    175
    Sep 28, 2019
    Air leak somewhere, check valve, purge valve, governor, air dryer filter, could be anyone of those, shouldn't be anything major.
    If it's holding air, you are good to keep going, get it fixed just before you feel like driving off a bridge due to the constant annoying purge
