Air Pressure on Tires?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by RTR, Jan 1, 2015.
  1. RTR
    RTR Light Load Member
    194
    49
    Alabama
    Got to reading the Michelin Tire pressure when checking them on my Truck today and saw where it stated pressure of 110 lbs. I have not read a lot up on this, but I do run 110 on my steers (XZA3+) and 100 on my Drives (XDN2). Just wondering if anyone else runs 110 on their drives or not? Also is there a website where it will show me what the RR on Tires are? Thanks!:biggrin_255:
  3. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    flood Thanks this.
  4. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
  5. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    I run the recommended pressures on the Michelin load rating charts. I run 105 on the steers, 95-100 on the drives (wide based). I got 220K out of my last steers (XZA3+), and they still had 8-10/32nd tread. I only changed them because I got $150 a tire casing credit and discount on the new ones. Basically a 2 for the price of 1 deal. My wide based (Xone XDN2 from the factory install) now have 348,000 on them, and they still have 14/32nd tread and wearing quite nicely.
    The Michelin website has all kinds of info on RR for theirs and other brands of tires. Look under the Tools menu at the top of the page.
    http://www.michelintruck.com
    I just filled up on fuel yesterday for $2.09 a gallon. Any perceived savings that might be out there by running max pressures is really not an issue. And tires also are designed to take some of the shock out of road bumps and such. It has been shown that some suspensions take a real beating by running tires over inflated. So one "might" save little on fuel, just to have to replace suspension bushings and such sooner. I just see no appreciable benefit to doing the max pressure thing. Irregardless of the latest radio show banter or whatever. Tires serve many purposes. Stopping distance is negatively affected by over inflation. Sure, one should not follow too close, but it is that idiot who pulls out in front of me, unexpectedly, on a two lane road that really concerns me. I want my tires to be their best at everything they do, and the R&D folks who designed the tire have done all the leg work and know how to make tires perform their best. Chasing a tenth of a mile mpg as the only consideration for my tire inflation choice doesn't fit into that game plan.
    But folks do goofy things to their cars, pickups, and big trucks all the time. Nothing will change except the names and the faces.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I was getting cupping on my drives and heal toe wear at 105 psi, I dropped the pressure to 85 psi and they are wearing good now. I haul 140,000 lbs super b's, traction is my main concern as I load in yards and fields and travel plenty of gravel. My trailer tires are at 80 psi so they float on the soft ground a little better.
    Before you cry "under inflated" look at the load and pressure charts and you'll see that I actually could go down to 75 psi on the drives. Michelin XDS2 .
    My trailer tires were wearing on the outer edges before, but they are leveling out nicely now too.
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    yeah on the tire pressure, what gets me is just the look of the tires when loaded at anything below 90. maybe I have been looking at over inflated tires too long. tires at 85-90 looks like a flat tire in the process.
  8. 201
    201 Road Train Member
    12,053
    24,610
    Apr 16, 2014
    high plains colorado
    Hi Cowpie, your post #4 makes about the best sense here. I never "pumped " my tires up either, and ran them at what you say. Running too much pressure always made the truck seem a little "squirrely", especially in rain or snow, not to mention what it does to the roads, if anyone cares about that. Like you say, R&D did their job, and I stuck to what was on the sidewall of the tire.
  9. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    [QUOTE="semi" retired;4393523]Hi Cowpie, your post #4 makes about the best sense here. I never "pumped " my tires up either, and ran them at what you say. Running too much pressure always made the truck seem a little "squirrely", especially in rain or snow, not to mention what it does to the roads, if anyone cares about that. Like you say, R&D did their job, and I stuck to what was on the sidewall of the tire.[/QUOTE]
    yeah but what is on the sidewall is max press , not ideal press. I always put max, cause I thought it was the recommended p.s.i. never new there was a calculations table until about 8 years ago.
  10. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    I was thinking the same thing. But you have to remember if you want to run low pressure and haul somewhat heavy, when DOT comes up behind you or beside you he is looking at the tires flexing. Maybe your more likely get pulled over and scaled? They have pulled me over a couple times and excuse was your tires looked squatted.
  11. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I may get a copy of michelins p.s.i. calculations table & keep in truck to show my tires are NOT under inflated.
