Air Lines to Pressure Gauges
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by zmster2033, Nov 28, 2018.
  1. zmster2033
    zmster2033 Light Load Member
    190
    251
    Apr 28, 2011
    Charlotte, NC
    Does anyone know if the o-ring seals for the airline connections that feed the air tank pressure gauge on the dash are replaceable? I have an air leak (very audible) coming from the hose that feeds the primary tank gauge behind the dash. We tried trimming the hose a little bit to make sure it wasn't chewed up and tried using a bit of silicone to help it seal. The air is pouring out this AM. Was wondering if anyone has experience with this and to see if the o-rings can be changed. This is a 2001 KW T2000.
  3. bjrc
    bjrc Light Load Member
    81
    96
    Sep 14, 2018
    Have never tried changing the o ring. Just replace the pushlock fitting on the back of the gauge would be best.
    zmster2033 Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Yes you usually can .need a dental pick to fish out the old o ring
    MartinFromBC and zmster2033 Thank this.
  5. zmster2033
    190
    251
    Apr 28, 2011
    Charlotte, NC
    This would be on the factory gauge cluster module, are the pushlock fittings able to be replaced? If so, do you unscrew them or how do you get them out?
  6. bjrc
    81
    96
    Sep 14, 2018
    On my old truck they just screw on the gauge, should be replaceable on any truck, may be harder to get to on a gauge cluster setup, not sure.
  7. MartinFromBC
    2,769
    12,476
    Oct 19, 2018
    Have replaced many Orings, so yes replaceable.
  8. uncleal13
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Try this.
    JohnC123 Thanks this.
