Air line fittings/ DOT
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Oct 12, 2019.
  1. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    Everything with Airlines and all of that I want to completely double-check I'm not going to have dot problems
    Could they have any problem with these fittings?
  3. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    No you won’t have any problems
  4. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    If it's too shiny DOT will look for something else to find.
    Rideandrepair and swaan Thank this.
  5. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Are you using stratoflex line or synflex. That fitting is not what is normally used for synflex, or is that for the rubber line like going to a brake can?
    Rideandrepair Thanks this.
  6. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Usually brass is marked if its DOT approved, but I think they are more concerned with the rubber lines, plastic lines, and the fittings adapting them to thread. Your adaptors to the valve should be OK.
    I would think you would have to really piss off the officer to get him to find that fitting.
    A nice coat of gloss could only help divert their attention.
    Dino soar Thanks this.
  7. Dino soar
    4,789
    26,858
    Dec 8, 2017
    They are the fittings for the Maxi brakes.
  8. Dino soar
    4,789
    26,858
    Dec 8, 2017
    They are not marked for DOT.
    The warehouse that I get them from sells all kinds of air brake parts and lines, so I figured they would be okay.
    I didn't really think about it too much until I installed them.
  9. Working2party
    608
    729
    Feb 10, 2018
    Kansas
    Like said, you’ll be fine, just don’t get caught running around with the officers wife!!!
  10. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Got you, those fittings are not marked normally, can actually be brass or steel even.
    Bean Jr. and Dino soar Thank this.
  11. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    Just remember not to mix up 45 vs 37 degree fittings. Steel jic hydraulic fittings are 37. Propane service and i believe air brake are 45. If im not mistaken.
